Sibolan S17 - 17" 2560x1440 @ 120hz USB Type C Powered Portable Gaming Monitor
Discussion in 'Displays' started by TheSandman2236, Aug 30, 2018.
  1. TheSandman2236
    TheSandman2236 2[H]4U
    2,551
    Mar 30, 2006
    Hey everyone! I'm just going to preface this. I've been dying for a more portable gaming monitor to take to LAN parties, big events (Quakecon, DreamHack etc), and a second monitor to use while I'm traveling. I've found that it's pretty common for Chinese manufacturers to take excess laptop displays, pair them with a controller board, an external case, and create dual purpose monitors/displays with them. Ever since the market was flooded with 120hz panels (skylake gaming laptops) I've been dying for one of these companies to re-purpose these AUO gaming panels.
    Well today, is that day. I stumbled upon one on eBay/Amazon with the price of $297.
    Strangely enough, it uses a Dell S2718D controller to handle the display. It also supports HDCP which is great. Let me know if you guys have any questions!
    Armenius, isp and phillyboy like this.
  2. Stargenx
    Stargenx n00b
    1
    Jan 9, 2015
    Really cool - is it IPS or TN? I see conflicting sources on that. Perhaps there are two versions. I'm extremely interested in this - maybe I'll get the generic panel + driver board direct from aliexpress. :p
  3. aschafer14
    aschafer14 n00b
    1
    Sep 4, 2018
    Can the monitored by powered via USB-C directly from the computer or will it only work plugged into the wall?
  4. isp
    isp 2[H]4U
    3,029
    Mar 15, 2002
    Thanks for sharing. How do you find the antiglare coating? How's the brightness?
  5. DoubleTap
    DoubleTap [H]ard|Gawd
    1,935
    Dec 16, 2010
    Wow, my 24" 1440p monitors can be hard to read.
    Is that a vesa mount on the back?
  6. HiCZoK
    HiCZoK Gawd
    811
    Sep 18, 2006
    I overall see going higher than 1080p a waste. Even on 27", 1080p is perfectly fine. Especially on 17". I use 15" 1080p dell ips laptop at work and it's very sharp and nice.
    Let's not forget that 17" crt's were agold standard and had even lower ppi.
  7. rabidz7
    rabidz7 [H]ard|Gawd
    1,238
    Jul 24, 2014
    Does this support backlight strobing/scanning by any chance?
  8. Armenius
    Armenius [H]ardForum Junkie
    15,938
    Jan 28, 2014
    It's a little better PPI than a 4K 27". It'll be fine with 150% scaling.
    The S2718D controller does not support black frame insertion of any kind, so I assume this doesn't either.
  9. Zil0
    Zil0 n00b
    1
    Sep 11, 2018
    Has anyone else who got one of these been able to get 120hz at 1440p? I can switch to 120 hz at 1440p and the monitor reports that it is running at 120 hz, but when using the UFO Test Frame skip checker, it appears that it is just skipping every other frame. 60hz at 1440p works fine, and 1080p at 120hz looks great on this monitor. The monitor will appear to work for for at any hz from 60 up to 120hz but the motion always looks like it's running at 60 hz when testing it at 1440p.
    I'm suspected that the monitor cannot actually do 120hz at 1440p and it's intentionally skipping frames while reporting that the monitor is actually going at 120 hz. I'm using a GTX 970 with only displayport 1.2, but that should be capable of at least running at 120 hz at 1440p for testing purposes.
    Krisium and Armenius like this.
  10. Armenius
    15,938
    Jan 28, 2014
    I thought it was a little sketchy considering the S2718D from which the controller comes from is a 60 Hz monitor.
  11. Digital Viper-X-
    Digital Viper-X- [H]ardForum Junkie
    13,502
    Dec 9, 2000
    So the OSD says 2718, the driver is 2417DG
  12. TheSandman2236
    2,551
    Mar 30, 2006
    Hey guys -- sorry I disappeared for a bit! What else can I answer?
  13. TheSandman2236
    2,551
    Mar 30, 2006
    It seems to be somewhere between a VA/TN
    Yep it can be bus powered (by laptop or desktop)
    Brightness is good, I don't have a way to measure the nits though :/
    Yep! two VESA 100 holes I believe
    Not sure, what's the best way to test?
