cornelious0_0
- Apr 6, 2003
Well, finished installing the Accelero S1 Rev2. It's working out SO much better then I expected with the single 92mm fan. Here's a comparison of my load temps after only about a minute or two before and after the Accelero installation:
Stock Cooler - 35% fan speed
GPU Temp.(DISPIO): 72c
GPU Temp.(MEMIO): 76c
GPU Temp.(SHADERCORE): 73c
VDDC Slave #1 Temperature: 66c
VDDC Slave #2 Temperature: 69c
VDDC Slave #3 Temperature: 68c
Accelero S1 Rev2 92mm
GPU Temp.(DISPIO): 55c
GPU Temp.(MEMIO): 59c
GPU Temp.(SHADERCORE): 56c
VDDC Slave #1 Temperature: 81c
VDDC Slave #2 Temperature: 86c
VDDC Slave #3 Temperature: 87c
GPU temps are all down up to 17c which is amazing under full load in Furmark! The VDDC temps are higher but still under 90c and completely acceptable. The reason for this is because the heatsink that comes with the Accelero isn't compatible with the HD4870 and I had to use a zip-tie to hold down one side.
All in all I'm very pleased. I'll have pics posted eventually, just wanted to let everyone know that even with a single 92mm fan under 40cfm the Accelero S1 Rev2 is MORE then capable of cooling the HD4870 and it's VRM's.
