FallenMystic
- Jan 20, 2006
Greetings all,
Just got Win 7 installed last night and so far everything is smooth, (well except for the fact it decided to run power save by disabling my NIC...) Other than that I'm getting used to it.
Current problems I'm running into is whenever I try to shut down my PC, (specs in sig,) it doesn't shut down, it reboots instead. I've tried a few reedit options that I found through searching, turning off a few things in the NIC's properties, (most places are relating the issue to a 'wake on lan' type of event
but nothing's worked... short of a hard shutdown.
Does anyone have any thoughts on this/has anyone run into this?
Many thanks,
Fallen
Many thanks,
Fallen
