Show your FIRE STRIKE ULTRA scores
Discussion in 'nVidia Flavor' started by UnrealCpu, Feb 6, 2016.
Should this benchmark competition include Multi Core Processors more than 4 physical cores?
Poll closed Jul 15, 2016.
  1. YES
    75.0%
  2. NO , because Physics score is unfair and in games it makes no real difference
    12.5%
  3. Include but add a separate spreadsheet for 4 physical core since games dont use more than 4 cores
    12.5%
  1. Armenius
    Armenius [H]ardForum Junkie
    11,849
    Jan 28, 2014
    Yeah, I can't see the whole thing but it looks like the entire loop is going through that single 140mm radiator on the back. Adding another fan to it for push-pull might help a little, but you really need more surface area to cool a loop with a pair of Titan X attached to it.
    Actually, looks like there is a radiator on the top. It didn't look like there was enough space for one at that angle. Might just be a skinny one.
  2. Vellinious
    Vellinious n00bie
    53
    Oct 23, 2015
    5820k @ 4.7, 970 FTW x 2 @ 1607 / 1998
    Score: 6193
    I scored 6 193 in Fire Strike Ultra
    5820K @ 4.7, 970 FTW x 1 @ 1630 / 2135
    Score: 3406
    I scored 3 406 in Fire Strike Ultra
    I bought a 290X a few months ago. Haven't run it through FS Ultra yet. Still fine tuning the bios, but, judging by what I've seen thus far, should be able to hit 3600+ pretty easy. Might do that this weekend. = )
  3. skypine27
    skypine27 Gawd
    657
    Apr 18, 2008
    Ya there are 3 x rad's in there . 360 mm up top, 420 mm rad in front, and 120 mm rad in rear. So there is quite a bit of surface area.
    But I use super low RPM fans (700 rpm or so) to keep the system silent.
    The actual components with the water blocks on them, i.e. the GPU's and CPUs, their temps stay very consistent during marathon gaming. But what does happen is, the whole "hot box" effect where the interior of the case heats up like an oven. This doesn't mess with the temps on the components with a water block attached to them but it does raise temps of all the other stuff, i.e. RAM, Mobo, mofsets.
    So Ive had some crashes after an hour or so of a heavy hitting game like Elite Dangerous (at 3440 x 1440 and 100 fps!) that are because one of the non water-cooled parts went above a reasonable temp.
    Anyway here's to a thread back from the dead!
  4. Supercharged_Z06
    Supercharged_Z06 [H]ard|Gawd
    1,855
    Nov 13, 2006
    skypine27, with the super low fan RPM's you are using, have you considered doubling up fans in a push/pull config? Also, with the fans you currently have, are they pushing air out of your case through the radiator, or are the pulling air in? If it's the latter, that would definitely contribute to your case getting thermally heat soaked over time. It sounds like you just need to tweak your internal case airflow a bit - having all the fans blow outwards would help.
  5. skypine27
    skypine27 Gawd
    657
    Apr 18, 2008
    Supercharged:
    I won't continue to thread hijack (lets get back to Firestrike Ultra scores) but most of my fans are intake so the case does turn into an oven over marathon gaming sessions but everything seems stable recently.
    POST YOUR SCORE!
  6. Supercharged_Z06
    1,855
    Nov 13, 2006
    Well, I did already. Post mine that is:
    I scored 9068 in Fire Strike Ultra
    Let's see some more scores folks!
  7. pclausen
    pclausen Limp Gawd
    331
    Jan 30, 2008
    Well, I get a 5061 score without my SLI bridge installed as seen here:
    [​IMG]
    My score goes up to 8739 with the SLI bridge installed, but Ultra then gives me a validation warning as the graphics cards drop from the system information detail.
    [​IMG]
    Any idea what might be causing that? CPU and GPUs are all on water and I'm running mild overclocks so far.
    [​IMG]
  8. pclausen
    pclausen Limp Gawd
    331
    Jan 30, 2008
    Ok, switched from using Asus AI to overclock the CPU and RAM to doing it manually in the BIOS. That apparently took care of the issue with Fire Strike Ultra not seeing the GPUs.
    So here's my valid score:
    [​IMG]
    CPU 4.6GHz @ 1.430V
    RAM @ 3333MHz @ 1.35V
    GPUs @ 1480MHz @ +50mV
    GPU RAM @ 8GHz
    Rig:
    [​IMG]
    [​IMG]
  9. Alkaladur
    Alkaladur Limp Gawd
    157
    Apr 9, 2016
    980ti @ 1490/8000, 5820k @ 4.5
  10. skypine27
    skypine27 Gawd
    657
    Apr 18, 2008
  11. Supercharged_Z06
    1,855
    Nov 13, 2006
  12. skypine27
    skypine27 Gawd
    657
    Apr 18, 2008
    Sorry for the foul language, I had been drinking while benching (it's the only way I can sit and watch that damn 3Dmark thing..
  13. DarthBeavis
    DarthBeavis [H]ardness Supreme
    5,482
    Feb 24, 2006
  14. Supercharged_Z06
    1,855
    Nov 13, 2006
    • Time measuring inaccurate
      This message indicates funny business with the system clock during benchmark run. In most cases, this means that, no, you cannot cheat in 3DMark by adjusting Windows timers during the benchmark run or otherwise tampering with the measurements done by the benchmark. If this message persists and you have not done anything out of the ordinary, it may indicate a hardware issue with the real time clock in your system or the presence of a background program that somehow twists the time-space continuum of your operating system in such a way that this anti-cheat detection is tripped.
    From: Troubleshooting 3DMark and PCMark results | Futuremark
    BIOS current? System clock set? Twisting the time-space continuum by using 4 Titan-X's in a single rig? Other than that, drawing a blank here... Nice score BTW!
  15. skypine27
    skypine27 Gawd
    657
    Apr 18, 2008
    Ive had the time measurement error a few times myself. No idea what causes it.
    I just re run 3DMark immediately after the report with the error, and its almost always gone the 2nd run.
  16. wareyore
    wareyore [H]Lite
    111
    Jan 1, 2014
  17. DarthBeavis
    5,482
    Feb 24, 2006
  18. Starrbuck
    Starrbuck 2[H]4U
    2,214
    Jun 12, 2005
  19. Dullard
    Dullard [H]ard|Gawd
    1,561
    Jun 28, 2012
  20. skypine27
    skypine27 Gawd
    657
    Apr 18, 2008
    I'm ordering 2 x 1080's on launch day from the nVidia store so I have kinda given up on OC'ing my Titan X'es :)
  21. RMXO
    RMXO Gawd
    555
    Aug 19, 2008
  22. UnrealCpu
    UnrealCpu 2[H]4U
    2,647
    Jun 20, 2003
    Waiting for GTX 1080 scores hehe
    cageymaru likes this.
  23. cageymaru
    cageymaru [H]ard|News
    16,692
    Apr 10, 2003
  24. Supercharged_Z06
    1,855
    Nov 13, 2006
  25. UnrealCpu
    UnrealCpu 2[H]4U
    2,647
    Jun 20, 2003
    Looks like most of us destroy the GTX 1080 single card. Wont be upgrading until non reference cards are released. Probably August, reference sucks !~,
    [​IMG] [​IMG]
  26. Supercharged_Z06
    1,855
    Nov 13, 2006
    Ya, it looks like the reference 1080 would be more of a side grade for those of us with OC'ed 980Ti's. Definitely going to sit this out until a 1080Ti arrives with HBM 2 memory... most likely late 4th quarter or early 1st quarter next year.
    The reference 1080 looks to be pretty lack luster in overall gaming performance, at least when compared to a nicely OC'ed 980Ti. (Like only a 10% performance gain) Will be interesting to see some real benchmarks/tests once the NDA's lift.
  27. UnrealCpu
    UnrealCpu 2[H]4U
    2,647
    Jun 20, 2003
    I am curious to know what SLI will offer for the GTX 1080 at 4k . Might be the first pair of cards to finally pull off a steady 60+fps in 4k gaming in SLI.
    anyway
    I could care less until there is a 144hz gsync IPS 4k monitor out. Until then I just dont see the need for this card because i know for sure the 1080 will not do 144 FPS at 4k or even 80fps in gaming. I would be surprised if it did. Other than that I think what we really need is a new intel processor with better IPC performance than skylake to satisfy my needs right now.
    Im sure the 1080 will be great for laptops thats about it until we see non reference with two 8 pin connectors . I have a feeling these reference cards will suck for overclocking and i also think these cards will only be a 5-10 percent improvement over a overclocks non reference ti
    I will upgrade once a new mobos come out with this new SLI bridge and better PCI-E lanes. Maybe NVlink? I dont know but i am sure as hell not paying for this stupid new SLI HB cable.
    According to EVGA, NVIDIA will not support three- and four-way SLI on the GeForce GTX 1080. They state that, even if you use the old, multi-way connectors, it will still be limited to two-way. The new SLI connector (called SLI HB) will provide better performance “than 2-way SLI did in the past on previous series”. This suggests that the old SLI connectors can be used with the GTX 1080, although with less performance and only for two cards.
    [​IMG]
    This is the only hard information that we have on this change, but I will elaborate a bit based on what I know about graphics APIs. Basically, SLI (and CrossFire) are simplifications of the multi-GPU load-balancing problems such that it is easy to do from within the driver, without the game's involvement. In DirectX 11 and earlier, the game cannot interface with the driver in that way at all. That does not apply to DirectX 12 and Vulkan, however. In those APIs, you will be able to explicitly load-balance by querying all graphics devices (including APUs) and split the commands yourself.
    Even though a few DirectX 12 games exist, it's still unclear how SLI and CrossFire will be utilized in the context of DirectX 12 and Vulkan. DirectX 12 has the tier of multi-GPU called “implicit multi-adapter,” which allows the driver to load balance. How will this decision affect those APIs? Could inter-card bandwidth even be offloaded via SLI HB in DirectX 12 and Vulkan at all? Not sure yet (but you would think that they would at least add a Vulkan extension). You should be able to use three GTX 1080s in titles that manually load-balance to three or more mismatched GPUs, but only for those games.
    If it relies upon SLI, which is everything DirectX 11, then you cannot. You definitely cannot".
    With this news i think i will wait until new mobos come with the SLI cable and possible better performance PCI-E lanes. Not impressed with the specs of the new line of GTX 10xx series reference cards.
    Probably best to wait until DEC 2016 for us 980ti owners or sell the cards before may 27. I am sure this is great news for a 970 owners or AMD owners who want to upgrade in June. Good luck to anyone who thinks they will see non reference 1080xx cards by August
  28. UnrealCpu
    UnrealCpu 2[H]4U
    2,647
    Jun 20, 2003
    Nvidia's new Pascal GPU is aimed at super computing, packing 15.3-billion transistors, 16-nm FinFET technology and HBM 2.0 memory. Meet the Tesla P100.
    During its big Tuesday Keynote at GTC 2016, Nvidia announced the Tesla P100 GPU. Based on the new Pascal architecture, which uses 16nm FinFET technology, it packs in 15.3 billion transistors, uses HBM2 memory, and steps up performance with some vigor. The chip is 600 mm square and connects to the memory with 4,000 wires (Maxwell has 384).
    It also includes NVLink, a new interconnect capable of 160 GB/s. NVLink is what Nvidia will use to connect the graphics card to the system instead of PCI-Express, which would not offer enough bandwidth. Nvidia claimed a 5x performance improvement with its new interconnect.
    The Tesla P100 has 16 GB of CoWoS (Chip on Wafer on Substrate) 3D-stacked HBM2 memory, with an enormous 720 GB/s memory bandwidth. It is a new unified memory architecture. The chip has 14 MB of shared memory register files with an aggregate throughput of 80 TB/s, along with 4 MB of L2 cache.
    I want HBM2 Nvidia card not GDDRX ! I have a feeling this is going to be a boring release for us 980ti owners
    Btw the new SLI news for the 1080x series card was leaked yesterday by a nvidia employee than deleted a few hours later on the geforce forums
    NDA is lifted on may 17
  29. skypine27
    skypine27 Gawd
    657
    Apr 18, 2008
    Not sure if you guys have seen this info but:
    Any "newer" LED sli bridge supports the new high bandwidth SLI tech. It's only the single, cheap ribbon cables that come with mobos that don't. There isn't any new tech in the new SLI bridge itself, the new tech is in the cards that allows them to use both prongs to talk to each other in 2-way SLI. So all those LED type 2- way bridges (Asus ROG, evga, and nvidia) already connect both prongs on both cards in 2-way SLI. I forgot what website I just read this on (this info was released today) but nvidia directly stated the above.
    So you don't have to wait for any new mobo to support his new High bandwidth SLI. Nor do you have to order that batman looking new SLI bridge from nvidia. You just need to snag any current nice looking LED bridge that uses both tabs on both cards.
    While one poster mentioned that most Of us are already beating the 1080, keep in mind most of us are running SLI and comparing it to a single 1080.
    2 X 1080s in SLI is going to destroy anything we have here in this thread.
    Even having just said that, I'm not going with reference cards this time. Most websites are staying that it's the single 8 pin power connection that is limiting the over clocking of the 1080. A german site even has already tested it with a better aftermarket cooler (air) and can't get any higher clock speeds. Again they are saying it hits the max power draw that a single 8 pin + the PCI-E slot is capable of before it temps out. And this on air. It's going to be an even bigger issue for water.
    I'm waiting for the aftermarket boards that have 2 X 8 pin power slots on them and then snagging 2 of them.
  30. Supercharged_Z06
    1,855
    Nov 13, 2006
    Nice info on the SLI bridge and agree with everything you've stated except for the above. Take a look at some of the solo card 980Ti scores in this thread - there are quite a few scoring well over the 5000 mark. Granted an overclocked 1080 is going to beat that by a little, but a stock 1080 isn't. (Scores I've seen peak at just under 5000) It seems the 980Ti's memory bandwidth helps it out a bit at 4K resolution. Not knocking the 1080, it's a great piece of kit, it's just that compared to nicely overclocked 980Ti, it isn't something that makes me want to rush out and buy it. Going to wait for the Ti variant... or at the very least, a non-reference board that can be put on water and fed adequately to make the OC potential worth pursuing. As is, going after a 10-15% bump with all the expense and hassle of upgrading just isn't worth it... to me at least.
  31. skypine27
    skypine27 Gawd
    657
    Apr 18, 2008
    Ya I wish I could find that article again so I could post a link. Im not having any luck. But it was definitely an Nvidia rep/spokesperson saying that any of the newer LED style SLI bridges that have connectors for both tabs on both cards would support thew new high bandwidth SLI (for 2 cards obviously, not 3 or 4). I was really happy after reading it, since I think the new Batman SLI bridge from nvidia looks terrible and I didnt want to have to wait for Asus ROG to make a nice looking new one.
    The same article also did an SLI test with an single tab sli bridge (i.e., not supporting the new high bandwidth mode) vs an LED double tabbed bridge using the new high bandwidth mode. They found that it didnt make any difference until you got into 4K gaming, and then having the double tabbed/high bandwidth bridge "smoothed out the dips (i.e. low points) in frame rates". It didnt increase the max frame rate from what I remember but just helped mitigate the low points.
    Again I cant find the article today but I'll keep looking.
    I agree with you in waiting for a non reference model that packs an 8+8 or an 8 +6 pin power connector on it, and put it under water and get 2100+ out of it. Here is a blurb from the german article that tested the 1080 with a better air cooler and still found its power, not temp, limited when it comes to overclocking:
    NVIDIA GeForce GTX 1080 tested with aftermarket cooler | VideoCardz.com
  32. skypine27
    skypine27 Gawd
    657
    Apr 18, 2008
    Update:
    Found the info on "old" dual tab SLI bridges supporting the new high bandwidth SLI on the 1080/1070:
    The Display Pipeline, SLI And GPU Boost 3.0 - Nvidia GeForce GTX 1080 Pascal Review
    "Nvidia adds that its SLI HB bridges aren’t the only ones able to support dual-link mode. Existing LED-lit bridges may also run at up to 650MHz if you use them on Pascal-based cards. Really, the flexible/bare PCB bridges are the ones you’ll want to transition away from if you’re running at 4K or higher. Consult the chart below for additional guidance from Nvidia:"
  33. skypine27
    skypine27 Gawd
    657
    Apr 18, 2008
    Some "good" news for those of us who want a 1080 under a custom loop, but DONT want single 8 pin reference cards.
    This is straight from EK tech support (I asked them about this):
    "thank you for contacting us.
    We will make full cover water blocks and backplates for some of custom GTX 1080 but at the moment we can't confirm for which versions we will decide.
    Best regards,
    Grega"
    So, to me, it sounds like we will (soon?) have options of a double 8 x pin 1080 and be able to slap an EK full block and snazzy looking backplate on it. Just a question of how long. For those that don't want to wait however, the:
    EVGA GTX 1080 Hydro Copper will definitely fit our bill:
    Custom GeForce GTX 1080 Roundup | VideoCardz.com
    I will grab two of them if EK fails to deliver in a reasonable amount of time. I prefer the snazzy looks of EK blocks and plates to the really plain black EVGA models so I'll wait a bit.
  34. Nytegard
    Nytegard 2[H]4U
    2,807
    Jan 8, 2004
    With the 1080 SLI that just arrived. I'll be rebenchmarking once I get the new SLI HB Bridge. This score is default, no overclocking whatsoever. Score: 8979
    NVIDIA GeForce GTX 1080 video card benchmark result - Intel Core i7-5960X,ASUSTeK COMPUTER INC. RAMPAGE V EXTREME
    *EDIT*
    OK, now with a valid score, and it's actually better than the previous one (9262), even with everything at stock. Probably due to all the unplugging and changing the USB ports when I restarted the computer and just had time to run a Firestrike Test.
    sk3tch and Shantarr like this.
  35. Supercharged_Z06
    1,855
    Nov 13, 2006
    It appears that a stock (no OC) 1080 SLI setup is performing pretty much on par with a OC'ed 980Ti SLI setup then... at least where Firestrike Ultra 4K is concerned. I highly doubt the newer SLI bridges will produce any further gains. (At least not in a 2 card SLI setup)
    I have a feeling that at 4K resolutions, the smaller bus on the 1080 is starting to hold it back a bit and the wider bus on the 980Ti is helping it keep up.
  36. Dullard
    Dullard [H]ard|Gawd
    1,561
    Jun 28, 2012
    Looking at the HOF, it appears the 1080s are starting to show up and are moving up the ranks. Not quite 10K SLI here, but very close
    Edit: The board link editor makes it read like this is my score, it's not.
    I scored 9 979 in Fire Strike Ultra
  37. sk3tch
    sk3tch [H]ard|Gawd
    1,305
    Sep 5, 2008
    What bridge are you using? If it's a newer "light-up" one then it is better than the old O.G.-style.
    I am thinking the HB SLI bridges will matter in 2-way SLI - especially because NVIDIA now no longer officially supports 3-way and 4-way SLI (it's about time, both are near pointless unless you're a pro bencher).
  38. Nytegard
    Nytegard 2[H]4U
    2,807
    Jan 8, 2004
    I have the old style flex strip SLI cable. The update should definitely help on this.
  39. sk3tch
    sk3tch [H]ard|Gawd
    1,305
    Sep 5, 2008
    NVIDIA GeForce GTX 1080 video card benchmark result - Intel Core i7-5960X,MSI X99S XPOWER AC (MS-7881)
    5,415
    Intel i7-5960X CPU @ 4GHz (Corsair H110 280mm Liquid CPU cooler with 2x Noctua NF-A14 iPPC-3000), G.SKILL Ripjaws 4 series 32GB 2800MHz DDR4, EVGA NVIDIA GeForce GTX 1080 FE (+200 core, +150 mem), Samsung 950 Pro SSD (512GB), Samsung 850 Pro SSD (1TB), and a 4TB Western Digital Black WD4003FZEX 7200RPM HDD on an MSI X99S XPOWER AC motherboard inside of a Cooler Master CM Storm Trooper full tower – powered by a Corsair AX1500i power supply (1500W; fully modular) with braided cables.
    Armenius likes this.
