Hi,
I have some onboard Realtek sound card. Im using optical cable to hook it to my amplifier which is some Pioneer (average quality 7.1 amplifier) then i have it connected to normal regular Koda stereo speakers (not some cheap pc speakers). My question is will it help me to get better sound if i buy better standalone sound card?
Im using my pc mainly to listen music through Tidal.
I have also Koss stereo headphones which sound really quiet when hooked into my pc realtek sound card. If i plug them through adapter into Pioneer amplifier i get strong sound distortion, not sure why. So there would be probably some gain with headphones but i dont use them too much with my pc so it wouldnt be deciding factor.
Thanks in advance for advices
cheers,
Kosmo
cheers,
Kosmo
