I'm looking to buy these parts:
pcpartpicker.com/list/vw37wV
The Asus Z170-AR is $95 after bundling with the 6600k which is already only $200 at Microcenter. I'll make the drive to Philly, it's only about 50 minutes:
»www.microcenter.com/prod ··· herboard
I can get this 1070 down to about $323 after rebates and cashback:
»jet.com/product/Gigabyte ··· 46788d66
Saves around $174 doing it this way. Do you think I will find a better deal on BF or CM or should I pull the trigger now?
Also, should I go with the motherboard in my first link or this one?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157681&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
