Solhokuten
- Dec 9, 2009
I already use gsync. Is there any benefit to be had by enabling fast sync as well.
lol thanks!
do NOT set your framerate cap to 165 with a 165 Hz gsync monitor. when framerate is at or within a few frames of the refresh rate limit of your monitor it begins to act like regular vsync. i haven't used a 165 Hz monitor so i don't know where this exact limit is but on 144 Hz monitors it's at ~138 which is about 96% of max refresh rate, equivalent for 165 Hz would be 158.No, fast sync with g-sync is pointless. The better option is to cap your frame rate at your max g-sync range. So for your monitor, set you max frame rate to 165. With lots of games you can do this in the options or in a config file. For everything else you'll have to use the Nvidia CP.
yes to the former, of course not to the latter.By the way, what do you mean by this? Do you start to get input delay like you do with vsync? Or do you mean it duplicates frames when you drop below 165, as if gsync wasn't on?
huge input lag isn't a problem, haha. thanks for the laugh.I wouldn't even call it a problem. No matter what display tech you use, you can't update faster than the maximum refresh rate of the monitor (unless you display partial frames aka screen tearing).
With a 165Hz monitor, it is unlikely you are running a much higher frame-rate than the monitor in modern games (in fact, you'd be lucky if you are above refresh rate at all unless on old games or at low resolution). Chances are, most games would run under 165FPS, in that case no lag.
If you are running maybe an old game and are getting crazy FPS (like 300FPS) then you can try Fast Sync, in this case it may actually help to give you input lag similar to V-Sync Off.
If you are somewhere in-between, you're probably safe with G-Sync/V-Sync On. There may be some small amount of lag, in the single ms range that you probably won't notice at all.
The OP is running a 165Hz monitor. One additional frame of lag is 6ms. Hardly huge.huge input lag isn't a problem, haha. thanks for the laugh.
