Nuby1Canuby
- Mar 4, 2008
Any idea what would happen if both computers tried to access the monitor at the same time?
My wife's computer is connected to the left hand monitor with the VGA cable.
My computer is connected to the left hand monitor with the DVI cable, to a mini display port to DVI active adapter.
The other two monitors are connected to my computer with the DVI cables.
My wife doesn't use her computer when I am gaming so I can use all 3 monitors.
I have a profile setup to only use the two right hand monitors.
The trouble is when I turn on the computer it uses the two left hand monitors before it switches over.
It's fine coming out of sleep mode, so I just make sure the 2 computers aren't using the left hand monitor at the same time.
