cjcox
- Jun 7, 2004
Truly fucking brilliant. You do realize this thread was started before we had actual sizes and pretty much just knew there would be something called a 3090 from a leaked name, right?
Also you can actually fit the asus tuf 3090 in the case if you do it right. You can probably fit any of them in a case with a dual rad loop.
Fitting in a case and being actually happy about it the end result might be two different things though...
