First, I'd like to thank everyone who has helped me out, Jim_G, _Gea, to name just a few. Great community you all have here! I know this is a long post, but I'm rather new to all this so I'll try to be thorough as I can for why I did what I did, maybe I'll help someone else out along the way!
Here is my tentative build. I'm extremely open to criticism & suggestions!
Case: Fractal Design Define XL
I opted to go with this because I do not have the space for a rack, as I am 22 years old and moving around quite a lot from house to house. I own a file-server (that I am selling) with this case and really like the space, and it will adequately hold my 12 hard drives.
Motherboard: Intel S1200BTL
As per Jim_Gs suggestion, I think it is best if I go with a server quality core, hence my motherboard decision.
Processor: Intel Core i3 2100
I simply cannot afford to grab the Xeon, though I know it is likely what is suggested. This still looks more than adequate for a server, I think.
RAM: Kingston KVR1333D3D8R9S/4G 4GB DDR3 1333MHz ECC Registered CL9 DIMM 1.5V Server Memory
Alright... admittedly I do not know much about ECC memory, in fact, Jim_G introduced me to it but it seems important. I was thinking of grabbing two of these sets for a total of 8GB.
SAS Expander: IBM ServeRAID M1015
Also, this was suggested to me. It will be powered 8 drives, with 4 others being powered by my motherboard. I intend on flashing it to LSI IT mode.
Hard drives: Hitachi 3TB 5400 RPM or WD 3TB drives
Not sure what to go with here... any suggestions?
Power supply: Seasonic S12II 520W EPS12V 20/24PIN ATX Power Supply Active PFC 80+ Bronze 6+8PIN PCI-E W/ 120MM Fan
Good reviews... any reason NOT to go with this?
I plan on running napp-it + OI on a USB flash disc drive which will be internally mounted.
In regards to teh L2ARC & ZIL... any suggestions? Is it really necessary to get an SSD for a moderately used home-server?
Thanks for any time you take in framing your suggestions. I know it was a long read.
- Will this fit in my case?
- Are there any newer motherboards out there within this price range ($200-$230 CDN)
- Do the SATA slots on this motherboard support 3TB drives?
- What are the pitfalls of this vs. a Xeon?
- Is this enough RAM?
- Is this compatible with my motherboard?
- Do you know of any less expensive RAM? (on NCIX)
- Will this be a bottle-neck or is it suitable?
