Setting up wirless in Kubuntu.
Neocorteqz
Running Kubuntu 8.04 beta (dual booted with wubi).
How do i setup linux with passworded router? I'm new to setting up linux with wireless.
the router if you need to know is a Netgear WGR614 v6.
I'm used to windows just popping up the necessary credentials box.
thanks.
hmm, problem with ./configure
Comes up with an error, i'll see if I can't post the error in the log output.
Assuming your wireless adapter was detected, have you tried clicking the little network connections icon on the taskbar? It usually gives you a list of wireless networks it can see if you have wireless.
Also, you're gonna find answers way quicker searching ubuntuforums, or googling with ubuntu as one of the search terms ;)
