Setting Up Solitaire Box For Elderly (advice appreciated)
Discussion in 'General Software' started by Neapolitan6th, Jan 10, 2019.
  1. Neapolitan6th
    Neapolitan6th Gawd
    937
    Nov 18, 2016
    Objective: Create a simple and easy to use Solitaire gaming box for an elderly family member.
    My Preferences:
    1. DIY or Prebuilt would be fine (cheaper is better)
    2. I want to avoid clunky interfaces like windows. If I can, I would make it a one click solution.
    3. I want the OS to be basicly locked. If it booted straight into fullscreen Solitaire that would be great.
    4. Any OS would be fine.
    5. The only peripheral needed would be a mouse. (No need for password protected login as it will not be internet connected)
    Any hints or advice anyone might have would be appreciated. My main experience is with Windows, but I can learn another OS if it is a better solution. Raspberry Pi comes to mind?
    I am not skilled in programming, but I can dabble if I have some guide to follow.
    Thanks for any thoughts you may have. Not really sure where to start so anything is appreciated.
  2. KCarpenter12
    KCarpenter12 n00bie
    26
    Nov 9, 2017
    Very simple... first you’ll need a raspberry pi, a power cord, hdmi cable, SD card and a USB mouse. Also a TV to plug into... download rasbian OS image on windows and use Win32 disk imager to put it on the SD card, download Solitaire and a couple quick edits to load the game on boot and you’re good to go!
    Neapolitan6th likes this.
  3. KCarpenter12
    KCarpenter12 n00bie
    26
    Nov 9, 2017
    I also recommend a wireless handheld mouse so they can use the main TV in the house... just switch the input over to HDMI2 and start playing
  4. Neapolitan6th
    Neapolitan6th Gawd
    937
    Nov 18, 2016
    Awesome thanks a ton I'll probably be picking up a raspberry pi soon and take your advice.
    We just had an elderly family member move in so this will be a great thing to keep her from getting bored during the day.
  5. KCarpenter12
    KCarpenter12 n00bie
    26
    Nov 9, 2017
    By using the USB port on the back of the tv to power the Pi, it should power up with the tv.
  6. Neapolitan6th
    Neapolitan6th Gawd
    937
    Nov 18, 2016
    Good idea!
    KCarpenter12 likes this.
  7. KCarpenter12
    KCarpenter12 n00bie
    26
    Nov 9, 2017
    Let us know how you make out...
  8. Neapolitan6th
    Neapolitan6th Gawd
    937
    Nov 18, 2016
    Will do (y)
