Gilthanis
[H]ard|DCer of the Year - 2014
- Jan 29, 2006
Einstein site is responsive again. Not sure about pulling work yet.
Yeah, I found that out earlier today. I'll likely stick to Einstein on my main system and leave any SRBase crunching to my server which only has a single GPU.Just a heads up on SRBase. If you have more than one GPU in a box, it will actually only use one of them. It would be better for you to either get familiar with config files or just bunker for Einstein.
If you go the SRBase's site, the invite code is on the front page. You can also create your account that way.Oh- I missed that, no primegrid? I'll swap over at lunch...
And I need an invite code for SRbase.
Should I limit SRBase to 50% CPU, or are those points more important than Universe?
I'm bored and may have joined in on SRBase![]()
Shhhh...Don't tell anyone!All your SRbase are belong to us![]()
Put your CPU's on either bunkering for Numberfields on throw 5 or leave them on Universe to pull and report what work it can. Just keep in mind that if your rig has more than one GPU, SRBase will actually only use the one that BOINC assigns as GPU0. So, either a cc_config file will be needed to exclude GPU1 or you should just have them run Einstein. We do need SRBase support something fierce so it just depends on your setup on what would be best.Should I limit SRBase to 50% CPU, or are those points more important than Universe?
Hey man. Thanks! Will keep this **secret**Shhhh...Don't tell anyone!
I see what you did there...smart ass!Hey man. Thanks! Will keep this **secret**![]()
Thanks for the help.Looking like ~5.5M PPD from me on SRBase.
TITLE Einstein@Home Tickler
:top
"C:\Program Files\BOINC\boinccmd" --host 127.0.0.1 --network_available
"C:\Program Files\BOINC\boinccmd" --host 127.0.0.1 --project http://einstein.phys.uwm.edu/ update
timeout /T 90
goto top
