SpeedSlayer
- Mar 15, 2002
Here is a project I want to undergo, but Im a quite a bit confusing on how to do it.
I have an old laptop that needs to be taken apart to get running (power adapter cable is broken). I was thinking of building a case for it that would mount on the bottom of the shelf right above the desk.
The case would be 3 layers. Layer 1 = Components, Layer 2 = Empty Spinning Wheel, Layer 3 = Monitor.
Here is what I want to do:
With control through a program (future control of a remote, meaning a program that can work with a remote), control the angle that monitor goes down. So basically, in the closed position the monitor would be closed like laptop is closed. When I send a command to the motor, the monitor opens (in the same way a laptop opens), until the degree I want it to stop at (or roughly at that degree)
The purpose of the second layer, is so that I can control the way the monitor is pointing. Turn on the motor, and set the angle (for example different angles are needed in different sitting arrangements so I want to be able to control that)
Here are my questions:
Any good websites to read up on control Servos/Steppers?
What kind of stepper would be need to lower and raised a 2lb monitor + frame?
Is a stepper or servo that best way to accomplish this?
I dont want the laptop running 24/7 so would the stepper or servo lower the monitor (due to the force of gravity) if there is no power in it?
Any other comments would be greatly appreciated.
