PCMusicGuy
- Feb 9, 2006
So I have 6 servers (Dell, Server 2012 R2) here in a test bed, where each has 6 network ports. Each server has a team consisting of two ports, where the 1st port goes to one Hirschmann Mach104 Gigabit switch, and the 2nd port goes to another. The switches can be thought of as an A/B setup for redundancy and the switches are uplinked/bridged/connected/ or whatever other term you prefer to call it.
Transferring files between the computers using the default admin network share results in seeing gigabit speed transfers (~110MBps). Let's call this network A.
One of the 6 servers, connects to an additional network (call this network B), also in a teamed fashion, through another separate pair of gigabit switches. On this other network, there are some 100Mb limited devices to which this server can communicate. Assuming all computer are off and I boot them. This server on both networks can achieve full GB speed (using a large file transfer as a test) talking to the other servers. If I use this server to talk to a 100Mb device, then this server is limited to 100Mb speeds on both A and B networks. The other five servers, only part of network A, work at expected gigabit speeds.
I've check the Hirschmann management software for all 4 switches and the 4 ports for this server and all indicate that this server is connected at 1Gbps everywhere. The OS also indicates that it is connected at 1Gbps as well for all ports. For some reason though, the actual throughput is limited to 100Mb on all ports. If I disconnect the B network, the server will achieve the gigabit speeds again.
The only other bit of information I can provide from memory is that we use the built in Server 2012 R2 teaming. I am trying to understand why it behaves this way. Any ideas?
