Server 2008 x64 - Print Server, Issues
Discussion in 'Operating Systems' started by Punkrulz, Jul 1, 2008.
  1. Punkrulz
    Punkrulz [H]ard|Gawd
    1,458
    Nov 11, 2001
    Hey guys,
    Here at my customer we are tinkering around with a few things. My boss would like me to try and implement our Server 2008 x64 machine as a print server. He would like me to remove the printers from the 3 other servers (All are 2003 Standard) so that we have one centralized source for printers. I've been messing around with it for a little while, and it seems very nice.
    I'm having an issue with one of the printers, which I expect to have on a few others. I am trying to use 1 printer / user as a test, which is an HP Color Laserjet 1600. About 95% of all of the printers we are using are HP. He also would like to make sure we use the HP Universal Print Driver, which makes sense. I am attempting to set all of this up on the Server 2008. I've installed the printer on the server using the TCP/IP address, and listed it on the directory. On the user's computer, which is Windows XP x32 w/ SP2, I attempt to add the printer.
    I then get an error message from the Universal driver in Windows Xp stating that it is the wrong driver for the printer, and wants me to install a different driver. I've also tried downloading the x64 1600 Driver and installing that onto the server, however I get the following error message:
    [​IMG]
    I'm not sure if I'm doing anything wrong, but nothing seems to work. Does anyone have any experience with this? Should I be installing a Windows x32 driver, since that's what will be installed on the clients as well? Or would I be installing an x64 driver, since that's what the server is?
    Thanks!
  2. xxEIEIOxx
    xxEIEIOxx 2[H]4U
    2,276
    Feb 1, 2008
    You would install both. You need the x64 driver so the server can access it, and x32 drivers for the client machines.
  3. Punkrulz
    1,458
    Nov 11, 2001
    Ok, that had answered my next question... so now I have another!
    It makes perfect sense that you would need to have both. My question to you is how can I install both, so that I can have the printer installed on the server, as well as have it deploy the appropriate driver when deployed to a user's machine?
  4. dbwillis
    dbwillis [H]ardness Supreme
    7,727
    Jul 9, 2002
    I havent checked with 2008 yet, but in 2003 there was a tab/button for 'additional drivers' where you would instal the XP or 32bit driver on the server
  5. Punkrulz
    1,458
    Nov 11, 2001
    Yep you're absolutely right, seems to work well too. :)
