I'll try and be as frank as possible.
Owned one WRT54G it kept dying, internet would not work at after a few days. Example: Setup Router browse the internet share files blah blah. I get home today around 6 internet still works, come back at ten and its completely dead, but....the light still blinks.
I've powered off and on the router and modem when the computer was off. Now here's the weird thing i can still access the router firmware and share files between two computers that are connected to the router so i'm sure its not a heat issue.There is just no way to browse the internet that portion dies, yet still blinks.
I have the SVEASOFT firmware installed and if i check the status all the IP stats are 0.0.0.0. So now what do I do?
I've heard of drop outs before but not complete dropouts on computers that are directly connected to the computer just those on wireless connections.
Nothing seems to help fix it and i'm not sure if its a network setup issue or something. There has to be a way to solve this problem.
Thanks
Thanks
