Red Squirrel
- Nov 29, 2009
I just bought this switch off Ebay and I can't seem to find anything online on the physical connection of this switch. It's not like normal switches where it just uses a ethernet type cable that goes to serial, it requires a female to female cable which does not exist anywhere so I ended up buying a gender changer for a normal cable I had but can't seem to get the prompt to come up. I'm using 9600, 8 data bits, no parity, 1 stop bits and no flow control. Do some wires have to be crossed a special way or something or do I need to type anything special in the console to get the prompt? I can't find much online on this switch. At least not as far as serial connectivity goes.
