I had the problem awhile back, and I posted here. It was sending/recieving 30million bytes per hour, its gone down since as you can see. I have no Anti-Virus software first off, McAfee's free virus scan says I have no virus, and Ive used "Search And Destroy" and it didnt find any spyware. Im on a network with another computer. Both computers connect into a router(US Robotics) and the Cable Modem connects into the router also. My NEC card is old(3com 3C450 Fast Ethernet Adapter), but I have tired my onboard LAN also (gotten the same problem). Im running Windows XP Pro also. I find that I send and recieve alot of traffic while Im playing Day of Defeat on STEAM, for example my send goes from 100k to 3.5million in a hour, and my recieve goes from 200k to 5.5million in a hour.
I finding these numbers under Network Connection and by double clicking on Local Area Connection. It is bytes not packets, Im sure of it. People have said the numbers aren't correct. I disagree, becuase before this problem I could play on this certain DOD server and ping 120 - 150 now seen the problem its been 200 - 250.
Any help would be great!
