Self-contained internal RAID to use as an ESXi datastore and boot device
Discussion in 'SSDs & Data Storage' started by idea, Aug 1, 2011.
  1. idea
    idea Gawd
    615
    Jan 24, 2005
    I'm building an "all in one" and I notice ESXi is picky about RAID controllers. It only likes hardware-based ones. Most onboard controllers, aka software RAID controllers, will not work. If you're not willing to install a hardware RAID controller, you can always run a single drive and hope for the best.
    So I'm looking at a new solution to the problem. New to me, anyway. I'm not exactly what to call these so I went with "Self-contained internal RAID" in the title. They are software based RAID controllers that perform RAID functions upstream from the SATA port they are plugged in to. Rather than configure it via the BIOS or OS levels, it is configured via a DIP switch usually on the rear of the unit. It is completely invisible to the OS so ESXi will never know that there is a RAID array behind the "SATA device" that it is booting off.
    I'm looking for something that supports mirroring (RAID1) two 2.5" SFF drives. SAS is preferred but SATA will do as well. Here are some items I found that can be installed inside my all-in-one box:
    These are really hard to google which is why I had to make a post about it. Does anyone have any other ideas?
  2. TheLastBoyscout
    TheLastBoyscout Limp Gawd
    142
    Feb 13, 2011
  3. _Gea
    _Gea 2[H]4U
    3,895
    Dec 5, 2010
    a hardware raid-1 for esxi should be fine
    i use a driverless http://www.raidsonic.de/en/products/soho-raid.php?we_objectID=5732
    it may help for a better availability
  4. idea
    idea Gawd
    615
    Jan 24, 2005
    I can't confirm this is a RAID1 capable device, but it's in stock for me: http://www.newegg.com/Product/Product.aspx?Item=N82E16817995068
  5. idea
    idea Gawd
    615
    Jan 24, 2005
    I found out the Sans Digital IR12TB I mentioned in the first post has an audible alarm for failure notifications. Too bad it's out of stock
  6. dashpuppy
    dashpuppy [H]ardness Supreme
    6,163
    May 5, 2010
  7. TheLastBoyscout
    142
    Feb 13, 2011
  8. idea
    idea Gawd
    615
    Jan 24, 2005
  9. apnar
    apnar [H]Lite
    106
    Jan 28, 2011
  10. hotzen
    hotzen Limp Gawd
    349
    Jan 29, 2011
    Man, that SYBA SY-PEX40045 looks indeed perfect.
    Too bad it is nowhere available in the EU ...
  11. bexamous
    bexamous [H]ard|Gawd
    1,670
    Dec 12, 2005
    :/ Anyone actually using this stuff? Seems like there has to be a better solution than relying on any of these.
    How do you even know if a drive fails?
  12. Beta4Me
    Beta4Me [H]Lite
    103
    Nov 3, 2011
    This is what I've been wondering too. Does it show you this somehow and/or pass on the information correctly so that the OS or something can detect it?
  13. hotzen
    hotzen Limp Gawd
    349
    Jan 29, 2011
    That is the big question plus: how to get this syba-stuff to europe :)
  14. idea
    idea Gawd
    615
    Jan 24, 2005
    LED turns red? Also, I know for a fact that the IR12TB model has an internal speaker that buzzes when a disks fails.
  15. idea
    idea Gawd
    615
    Jan 24, 2005
    I posted about ********** up above, but I did not include these items that they make:
    http://www.**********.com.cn/en/Products.aspx?typeid=57
    http://www.**********.com.cn/en/images/2011720113944406.jpg http://www.**********.com.cn/en/images/2011720113815718.jpg
    http://www.**********.com.cn/en/images/2011469233234.jpg http://www.**********.com.cn/en/images/20114692230546.jpg
  16. idea
    idea Gawd
    615
    Jan 24, 2005
    Here are two more interesting products from the IOI Technology Corporation
    IMIRROR525A
    [​IMG]
    SPM394
    [​IMG]
  17. athlon1.2
    athlon1.2 [H]ardness Supreme
    5,489
    Oct 10, 2001
    I assume this only works for "RAID 1" If you start using it from when the drive is first formatted?
    How exactly does this work, does it just send the signals to both drives? What if one drive returns read errors?
  18. Red Falcon
    Red Falcon [H]ardForum Junkie
    10,127
    May 7, 2007
    Just fyi, it's called FakeRAID or motherboard RAID, software RAID is totally different.
  19. idea
    idea Gawd
    615
    Jan 24, 2005
    I bought the ********** 229rsh I mentioned in an earlier post. It was around $65 shipped from their eBay store. About half the price of anything else. I put in a matching pair of 2.5" 5400RPM drives and set it to RAID1. I'm only getting 5MB/s read/write. Something is wrong.
    I might just return it, I don't like it's cheap construction anyway. It feels flimsy. You need the key to remove the drive. If I ever lost the keys I'd be in big trouble.
    Then again, I might not. I'm too lazy to order another and I don't care if I get 5MB/s. It's just for ESXi + Solaris boot drives.
  20. hotzen
    hotzen Limp Gawd
    349
    Jan 29, 2011
    I plan to purchase the ********** CAS3922-S2R and wonder
    - whether I must use the shipped RAID-software (which I expect to be super-crappy)
    - how I am noticed of hdd/raid errors
    - if this thing is decently working in RAID 1 as a ESXi vm-datastore
    anyone experience with this cheapo stuff?
  21. patrickdk
    patrickdk Gawd
    744
    Jan 3, 2012
    finding a raid solution for esx is pretty easy.
    If it requires software, it won't work. Lucky that card doesn't require software though.
  22. hotzen
    hotzen Limp Gawd
    349
    Jan 29, 2011
    Btw, the ********** CAS3922-S2R seems [1] to use the JMicron JMB390 [2].
    After a bit of googling the old vertex apex did use the very same JMB390 for internal Raid0 [3].
    So these crappy 5MB/sec look like there is really something wrong, doesn't it?
    [1] http://storageanddrivesblog.blogspot.com/2011/10/sata-x-2-**********-cas3922-s2r-sata2-raid.html
    [2] http://www.jmicron.com/Product_JMB390.htm
    [3] http://bench mark reviews.com/index.php?option=com_content&task=view&id=290&Itemid=60 (the forum is killing this url??)
  23. chune
    chune n00b
    62
    Nov 2, 2013
    Any updates how this is working for esxi? Thinking about picking up one of these so I dont have to waste a pci slot on my boot array for esxi+oi: http:///16YlLlc
    I'm hoping it has some sort of audible alarm but it doesn't look like it. Same jmb390 chip though...
