So I just found something interesting.. anyone else running the
G:\ATSC_THTF_SY14343_ST2975C_CMI_V500dk1_P01_20140707
firmware?
Never noticed it before because I never tried changing the color format away from RGB, but YCbCr444 is now an option at 3840x2160. Still 30hz, but it's 444 color, not 420 or 422.
After 2 days of pixelfckng i have preliminary results from Spyder4express calibration of a Seiki 39".
I am tired of trial and error, so braver souls could improve my results and remove the overcast greens and undercut-ed reds, but 99% of sRGB is definitevely something to write home for a $500 display with a $80 colorimeter. Considering that i am partially color blind
For the record, a factory reset showed that out of the box the "normal" color temp achieves 96% of sRGB, with much loss from reds and too much green and blue.
A strange behavior spyder4express increased the minimum brightness necessary to pass black level tests in lagom, The TV has best contrast around brightness 59 so i lost some raw contrast.
the test that showed greatest improvement over manual calibration was white levels, now the last white level- 254 appears over a much greater range of contrast and brightness settings.
I am running at:
Backlight 100
Contrast 43
Brightness 70
Color mode normal
gain red 134
gain green 113
gain blue 123
offset red 569
offset green 471
offset blue 451
There is probably another program or a hack that would allow me to see the white point temperature of this calibration or the raw contrast ratio, but the software included on the spyder4express just informs the color space coverage: 99% sRGB, 70% NTSC, 76% adobe RGB.
i took the liberty of searching my own post to answer the question
Agree. The 40 inch non pro is still available for $340.I think they are pushing hard for the 40" Pro, but I doubt it will take off. The allure of the 39/50 was that they were so cheap + they worked well enough.
one random blackout once in a blue moon can be blamed on the HDMI cable. try "24AWG HDMI" on ebay or amazon. now if you TV starts random blackouts after 1 hour of use and them the blackouts become more and more frequent, you have a bad board. i suggest replacing the power board and possibly the main board as well
So i have the 50" SE50UY04 tv and am having problems with 1080p @ 120hz. I have been using it for months 3840x2160 and it has been fine. So it will just black out every half hour or so, either playing games, desktop, or just watching plex.
I have flashed the custom firmware that allows me to select 120hz and ufo test shows i am running at 120hz. I have an ATI 280x hooked up via HDMI. I have read around about other people having this issue. But haven't really found an answer.
The thing is, it only black outs at 120hz in 1080p. 60hz runs fine.
ooooo
I wasn't expecting to get this, but I got the innolux documentaiton on the i2c interface for both their vx1 panels and the lvds ones. This should be interesting
Is this work of any use to the owner of the 70" with the V-by-one 16-lane interface? I'd love to run higher than 4k30 and 1440p60.
Working at 1080p120. Now to test how far this can go. I know the controller can do 1080p240 and 4k60...
Of course this is no-latency and RGB 8bpc/10bpc too.
How'd the testing go?
With the official i2c commands, it doesn't overclock well at all. 125Hz is fine, 130 is not. At 4k, even 33Hz fails. Maybe there is an i2c command that puts the tcon into a dumb mode, but so far I have not found this. I haven't read the entirety of this megathread, but has anyone managed to get no-frameskiping overclocks out of this panel?
In about a week, I will receive the first vx1 PCBs and I already have a 4k60 tcon for this panel with the vx1 interface. I fully expect that this will work at 4k60+1080p120 with this new setup, but probably with similar not-overclcokable characteristics.
Vizio V500DK2-CKS2 T-Con Board (50-inch models ONLY)What kind of additional hardware would someone that has the Seiki TV need to use it with a VX1 interface vs LVDS?
I haven't seen any overclocks surpass the ones you've listed.
I had a skyworth 39 with this panel and was unable to replicate their results. Tried a few different FWs for it too.The only sucessful report of Ocing on the 39" panel was on the Skyworth model. Skyworth parts are available on chinese sites. there are quite a few post [H]ere about the hardware, and one of those mentions a place where you can get pdfs of the technical aspects on the Skyworth hardware. Pardon my ignorance, but is it possible that the same panel has different "firmwares"?
I believed that simply putting a Skyworth mobo + power board inside a seiki chassi would solve it...
First image at 4k60. colorspace, bitdepth, and lane mapping are all wrong, along with a bad signal line on one of the boards, so I need to tweak the firmware a bit and inspect for a soldering failure. Almost there
Colorspace fixed. Pretty sure all of the green is from poor connections. The boards are stacked togeher at an angle right now because of a clearance issue, maybe the inner connector isn't mating properly. I'll have an extension in a few days, will update then.
