that is true. 2 problems:That's a passive adapter and it changes a DP output to a hdmi output. The question is about having the display have an hdmi input.
So, enjoying my 39", but the windows resizing and moving to the corner of the monitor whne the monitor is turned off is falling into the classification of SUCKS. Is buying an HDMI detective the only solution to this???
I found a thread where folks made a registry adjustment to help:
http:///Nbwo5T
But, it seems like it only keeps the windows from resizing, not from moving to the corner...must...find...fix....
http:///Nbwo5T
1. Do you still need any HDMI 1.4 input which is capable only 4K@30Hz? (There are no HDMI 2.0 chips yet available.)
2. Would you go for this solution, even knowing you will loose your Seiki's board with all its inputs (TV, tuner, coaxial, 3 x HDMI 1.4, VGA etc.)?
3. Any other "MUST HAVE" or "NICE TO HAVE" features I have not mentioned?
Sinuhet
1) No.
2) Yes.
3) MUST HAVE: 120Hz @ 1080p
(Seiki 39)UPGRADE OF 39" and 50" SEIKI TO 4K@60
NOW, a few questions on you:
Sinuhet
1) no
2) Yes, but can I swap the Seiki board back? Sorry if this has already been answered.
3) Also must have 120hz @ 1080P
I would be a go for this solution as soon as it's ready.
Hi guys
I have a good message for you. It looks like we will be able to provide "4K@60Hz upgrade" for both 39" and 50" Seikis.
The upgrade should consist of:
- new Tcon board (to be replaced in the display itself)
- input board (1 x DP 1.2 input, no other video inputs)
- necessary cables
- new metalwork which matches connectors present on input board (DP, USB)
This MEANS you will not be able to use Seiki's proprietary board with all its input connectors etc, because it will be physically removed from the TV due to upgrade.
Endpoint:
- true 4K@60Hz via 1 x DP 1.2
- significant reduction in input lag!!!
- you will still get audio coming via DP 1.2 on Seiki's speakers (our board will have audio out connector)
- USB hub to connect keyboard/mouse or other devices
- you will be able to use Seiki's remote control to power on/off the TV
- you will be able to use Seiki's buttons on the side of the TV
- the functionality of Seiki's blue LED should stay the same
- the IR controller commands can be forwarded by USB to your operating system
Sinuhet
I heard about someone covering up pin 19 or something on the HDMI cable to stop this as well but honestly if going to that extreme I think I would just buy an HDMI detective.
3. would a 48hz mode be possible? (for smooth playback of 24fps movies in 4K mode), or is the panel limited to 120 "only"?
understood but with the new adapter, 4k60hz is max, iirc. so we have the usual 60hz/24fps problem. thats why i asked for 48 fps support. i'd take 72hz too120 is a multiple of 24, so it should handle that rate without issue.
that is true and that is what we are ultimatelly aiming..120 is a multiple of 24, so it should handle that rate without issue.
Who is we?UPGRADE OF 39" and 50" SEIKI TO 4K@60
Hi guys
I have a good message for you. It looks like we will be able to provide "4K@60Hz ...
I would care about proper scaling for 2560x1440@60hz as well.
Neither did I, but not all of us have triple titans to support AAA gaming @2160p.
And I'd like to game higher than 1080p with somewhat decent scaling.
Sinuhet
Sinuhet
Has anyone tried to get 2880x1620 to run? @60hz?
Maybe the scaling on that is better than at 1440p.
Yes, you can create 2880x1620@60 Hz custom resolution (I have GTX780).Yeah but people are getting better results on the Sony 4ks. I was wondering is people had been able to do tv (not GPU) scaling for 2880x1620 to be able to get 60hz.
It's about half the number of pixels (vs. Uhd) so 60hz is theoretically possible and it might scale better than 2560x1440.
Awesome... Kind of.
Is 2880x1620 inferior or equal to 2560x1440, in regards to scaling.
Hmm. Interesting. I figured the math would make 1620p better.
