People are saying this TV is good for gaming, but isn't 24ms input lag really high?
Maybe not a "pro gamer", but it should be fine for the vast majority of us "casual gamers" (I define casual as being not a pro or someone who doesn't make 10ms or less a priority in their life).
Here's a nice article about input lag (and how it's tested):
TFTcentral's input lag testing guide
Using their classification, this TV goes under their "Class 2", which they define as "moderate lag, but should be fine for many gamers". Seems about right.
If you need further clarification about the difference between input lag, response rate, and refresh time, just check out their monitor reviews.
I say 35ms MAX for play-able response time on a tv.
Anything after that and you will see horrible ghosting. IMO anyway.
I also believe this TV has a built in scaler if I'm not mistaken. I ran it in 1080P 60Hz via the NVIDIA shield and the picture was almost as clear as running it in 4k 60Hz natively.
I can't get mine to work do 4k@60hz. The screen had green lines and drops the image.
It doesn't work for my PC or Shield TV, both work with my Samsung 6400 series.
Try a different HDMI cable.
I've used 3 different cables, different inputs, and made sure they were all set to 2.0 and not 1.4. I'll be returning it tomorrow.
Definitely sounds like you had bad luck on it, especially if even power-cycling on/off your system doesn't work (last-ditch thing to do).
Are we talking about 2 different things?
Thought only displayport did 60hz and HDMI was 30hz.
Try unplugging all your hdmi connections and doing a factory reset in the service menu. Mine was going to green lines/green screen on all inputs after watching youtube videos and it seems to have fixed it.
