Anyone know what type of panel is in it?
I picked one of these up yesterday, here is the EDID from the UGT
EDID from the UGT.
Monitor
Model name............... SE42UGT
Manufacturer............. SEK
Plug and Play ID......... SEK0030
Serial number............ n/a
Manufacture date......... 2015, ISO week 26
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 930 x 540 mm (42.3 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.340
Green chromaticity....... Gx 0.300 - Gy 0.690
Blue chromaticity........ Bx 0.138 - By 0.038
White point (default).... Wx 0.282 - Wy 0.297
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 31-140kHz
Vertical scan range...... 59-70Hz
Video bandwidth.......... 600MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 3840x2160p at 60Hz (16:9)
Modeline............... "3840x2160" 594.000 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync
Detailed timing #1....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
2288 x 1430p at 61Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 2
Detailed timing #1....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #2....... 1440x480i at 60Hz (16:9)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 480p at 60Hz - EDTV (16:9, 32:27)
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
AC-3 2-channel, 20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 2.0.0.0
Supports AI (ACP, ISRC).. No
Supports 48bpp........... Yes
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 340MHz
Audio/video latency (p).. n/a
Audio/video latency (i).. n/a
HDMI video capabilities.. Yes
EDID screen size......... No additional info
3D formats supported..... Not supported
Data payload............. 030C002000784420008001020304
IEEE registration number. 0xC45DD8
CEC physical address..... 0.1.7.8
Supports AI (ACP, ISRC).. Yes
Supports 36bpp........... No
Supports 30bpp........... No
Maximum TMDS clock....... 35MHz
CE colorimetry data
xvYCC709 support......... Yes
xvYCC601 support......... Yes
sYCC601 support.......... No
AdobeYCC601 support...... No
AdobeRGB support......... No
Metadata profile flags... 0x01
Reserved video related data
Data payload............. 0F000000
Report information
Date generated........... 12/28/2015
Software revision........ 2.90.0.1002
Data source.............. Real-time 0x0012
Its been confirmed it accepts a 4:4:4 input but from what ive read it downsamples it to 4:4;2 before it displays it. Hopefully this guy can provide us with the test images.It does indeed do 4:4:4.
Have you confirmed and tried the test images?
Edit: just looked at his post history and hes using an amd card and waiting on a display port to hdmi adaptor. Not exactly a good test mule, we need someone with a gtx 900 series thats is proven to be able to do 4k@60hz 4:4:4 color. By adding an adapter this guy will be adding additional input lag and prob wont be able to get 4:4:4 whether the screen will accept it or not.
So anyone with an opinion of how the monitor looks with text and how viable is it for gaming?
in the review video, the guys only running it at 30hz, but theres an absurd amount of input lag being shown.
https://youtu.be/6YZzl9A_GxI?t=418
Agree'd on the adapter and yes to the GTX 9 series card.
I just received my 10% off coupon code and have 3 more days to decide if I want to buy. Need someone to confirm 4:4:4 and i'm all in.
Later on he stated that when he hooked it to his desktop the lag went away. Only the Shield TV had the lag. Then I watched this video. He has a 980ti and he demonstrated the amount of lag you get when playing GTA V. Just skip to the 1:15 minute mark to see the PC demonstration. I didn't see much lag when he was playing GTA V.
[I'm back in Windows 10.]
Does 1920x1080 at 144hz (Blur Busters valid). Better than the Seiki 39.
[i just finished the 10586 update]
4:4:4!
The NVidia Control Panel is now giving me RGB, YCbCr422 and YCbCr444 for color output formats. 422 looks like jpeg compressions, RGB and 444 are crystal clear - verified with http://cdn.avsforum.com/b/b4/b4a44044_vbattach208609.png . Both bottom lines are perfect.
Do you have a camera capable of getting us a close up (macro) shot of the last two lines in that image?
From what I understand the TV EDID says that it supports 4:4:4 chroma, but the TV itself converts it back to 4:2:2 before it's displayed. So I'd love to see a picture of your set doing successful full on 4:4:4 chroma....
4:4:4!
