Anyone tested input lag yet?
Ordered one last night from Amazon, paid the $10 for Saturday delivery. Kinda excited. And one good thing about huge displays as monitors, my current 39" Seiki will now live on as a TV in the bedroom. Can't argue with value like that.
Appreciate that, and glad it solved your resolution issues.
Now, if someone could address the 6-bit/8-bit issue I could come closer to making a decision. Hopefully some reviews of this thing surface soon.
I tried this test:
http://photo.net/digital-darkroom-forum/00GkGu
Not sure how accurate it is. I see no dithering. Do you know of any other tests?
Just did this:
http://www.avsforum.com/forum/166-l...-s-dithering-technique-pictures-included.html
I can see a very slight line down the middle, not so much a line but an edge between the two sides... Both images look teh same. Not sure if this helps at all.
I'll try my usb hub tonight.
Sorry...Got home and now I realize that it doesn't come with the USB cable. I doubt I'll ever buy one since I don't have much use for the hub.
Another question for those who have this display:
Does it have a pixel orbiting feature like the Philips BDM4065UC?
^ thank you, plifzig. You just saved me from purchasing the Seiki instead of waiting on the Philips. I HATE cheap touch OSD bullshit...
I'm sure its not as good as the Philips osd, but I've never understood why people care that much about that kind if thing. On a monitor you typically set it once and then never touch it again.
Don't know what that is. How would I check that?
On another note: I restarted computer for a non-display related something and was greeted with a 4k@30hz OSD message when Windows booted back up. Utterly awful performance just dragging the mouse around. To fix it, I didn't unplug the DisplayPort cable, but instead changed the DP 1.2 to DP 1.1 and back again to DP 1.2 in the menu and that allowed me the 60Hz option in the Windows display settings.
This alone made me aware of how shitty/finicky the menu buttons function on this screen. The "buttons" on this aren't buttons at all, but touch sensors where there is no type of physical feedback and you don't even need to make physical contact to trigger them. The Philips joystick-style menu controls will prove superior, no doubt. I spent 25% of the time figuring out that I'd overshot an option I was looking for because the darn thing is so sensitive (unless it decides it isn't sensitive). This also comes into play when finding the option, say brightness, and it goes from 30 to 90 in 2 seconds when what you're trying to do is bump it up 5 at a time.
srphoenix, this would be true if this were a single-input Korean monitor, but there are many instances when I have to deal with OSD on my current monitor (34UM95 until the Philips is shipped by Amazon).
I admit the hardware calibration is usually a once-a-quarter thing (first-time setup for most users, if at all), but some examples of "everyday" OSD adventures:
1) Dealing with PIP/PBP
2) Changing between devices
3) Probably the most used for me: HARDWARE VOLUME CONTROL (sorry, but my desk doesn't have space for an AVR that won't even work with Displayport).
4) The Seiki has a known issue where it auto-switches between active inputs. If one connection is disconnected/turned off, it automatically fails over to the next active connection. This would be another everyday situation where yes, you do need to deal with the shitty touch OSD they've implemented.
I'm not saying it's the end of the world, but it's certainly a deal breaker for me. I've had to deal with touch OSD buttons when using low end TVs whose remotes are missing, and it's REALLY annoying when you're pressing the buttons and they decide not to respond except when they want to go into TURBO mode. It gets worse if you're working in dimly lit situations and forgot the button layout -_-
Anyone consider this vs the Panasonic 40" vs the Samsung 40/48" thread?
Yes, and the Samsung has won the battle for my personal choice it seems.
The verified 4k@60Hz with 4:4:4, combined with just 21ms lag, combined with a 48" size option, combined with the reviews on the curved effect for PC gaming, all for around a thousand bucks, sealed the easy win.
Amazing how we looked forward to this Seiki line for months, only to have it become a distant memory in just a few days...
Just glad to have so many great few options now, good stuff.
Which Panasonic are you referring to, and does it do 4:4:4? I like Panasonic products but I'm not aware of any of their TVs that are go-to options for PC gamers right now (based on my limited research).
Which Samsung, exactly? Can you link to this verification, as I know many people have been waiting on confirmation of 4:4:4. Which series is it? Seems like there were several options between their 6xxx and 7xxx lines.
edit: Are you referring to this thread?
Thanks! Definitely good to have more options but hopefully there is something in 40"-42" flavor because I'm almost certain that 48" is too large for me (40" was pushing it as is!).
Wondering if one of those samsung tvs can replace my 32" 4k acer B326HK
Yeah only if you have a card with HDMI 2.0. I have xfired 290xs so display port is the only option for me.
Well I just cancelled my Phillips order, and when I tried to order the Seiki this is what I got from Amazon's website:
"Item Under Review
This item is currently unavailable because customers have told us there may be something wrong with our inventory of the item, the way we are shipping it, or the way it's described here. (Thanks for the tip!)
We're working to fix the problem as quickly as possible."
Just my luck! hahahahah
Return rate is probably too high. Might not mean one specific issue but could be a range of issues that people experience. Could be simply that lots of people used the included dp cable which apparently sucks and they return the monitor instead of replacing the cable. Or it could be that seiki just has piss poor quality control and a range defects get out.
A vizio tv I bought had that same message on amazon, I ended up returning it 3 times all for different problems with the tv.
New Crossover version of this panel for 699:
http://www.amazon.com/Crossover-Com...8&qid=1427900284&sr=8-29&keywords=40"+monitor
Flicker Free also
