Seasonic Focus Plus Gold 850W CPU Power Cable
fx9
I was going to use this Seasonic Focus Plus Gold 850W PSU I had lying around for my new build but realized it only comes with a single 8 pin EPS/CPU Power connector but the new motherboard Asus B550-pro Tuf has an 8 pin + 4 pin CPU connector. Do I need to buy another CPU power cable off ebay or cablemod to get this to work? I hear the 8 pin without the 4 pin connected should be fine for most purposes but I hear conflicting responses.
I just bought another CPU power connector off ebay that says it works for my PSU but before plugging it in I used a multi meter to measure the new cable continuity versus the original CPU cable and sure enough the pin outs are different. Best not use this cable or it'll release the magic smoke. Any thoughts?
Definitely don't use the ebay cable.
You don't need both the 8 and 4+4 to use your mb. One will work without the other.
If you want to use both, either contact Seasonic for a replacement (i believe they sell Individual cables)or go to Cablemod and use their compatibility guide and buy one of theirs. You may not be able to get a flat black ribbon cable from Cablemod.
What are you trying to power? Most of the time the additional pins aren't needed and you're fine with an 8 pin connector. If you have any other seasonic CPU cables lying around they may work (I've had success with everything so far, but you could run into issues).
