Sealed Windows 11 Pro 64 bit 23H2 DVD + Key Card
Since when does MS put "Full Version" on the disc... and the key is "scratch and sniff"....
I smell BS on this... (OP also posted this twice)
Do they sell DVD drives too? ;-)
I bought a console because it's hard to get a pc case with 5.25 bays these days if you need a case pronto. we use it to play 4k blurays and for guests.
It sure is.
Some still use those 5.25" bays for other things (place for port expansion, fan controllers, etc.).
I just use the silverstone 1 to 8 fan splitters with a sata power connector and a 4 pin for signaling off the motherboard but this works best with identical fans per splitter.
It sure is.
I have this one and I like it a lot.
For my HTPCs I have various flavors of this guy which I also like.
