Seagate sued over unreliable Barracuda, Backup Plus 3TB hard drives
Discussion in 'SSDs & Data Storage' started by rat, Feb 1, 2016.
  1. rat
    rat [H]ardness Supreme
    4,915
    Apr 16, 2008
    http://www.macnn.com/articles/16/02...aw.firm.seeks.information.from.owners.132264/
  2. Sp33dFr33k
    Sp33dFr33k 2[H]4U
    2,481
    Apr 20, 2002
    Lawyers = $5,000,000+
    Class = coupon for a seagate hard drive at 30% off.
  3. mwroobel
    mwroobel [H]ardness Supreme
    4,942
    Jul 24, 2008
    FTFY
  4. Technical_Advisor
    Technical_Advisor [H]Lite
    113
    Jan 15, 2016
    I have never had any trouble with a Seagate Drive, but I never bought the bottom tier either.
  5. drescherjm
    drescherjm [H]ardForum Junkie
    14,475
    Nov 19, 2008
    I assume you are talking about a few drives and not 100s of drives.
  6. rat
    4,915
    Apr 16, 2008
    Backblaze is approaching 50% failure rates on some Seagate models.
  7. munkle
    munkle [H]ardForum Junkie
    11,196
    Jan 16, 2005
    All of the 3tb seagates I bought died around the 1 year mark. I doubt I'll get anything out of this because they'll probably require a receipt which I don't have any more. If I'm lucky they'll take the serial number and I'll get $0.45 for each drive.
  8. ToddW2
    ToddW2 2[H]4U
    4,019
    Nov 8, 2004
    so people who buy budget drives should be expecting 50% failure rate or ???? :rolleyes:
  9. KazeoHin
    KazeoHin [H]ardness Supreme
    7,860
    Sep 7, 2011
    I'm pretty sure some Seagate drives had a higher than 100% failure rate
    Lets just take a step back and let that soak in.
    That means drives are dying so frequently within the warranty period, that the replacement drives shipped out are then failing again within the warranty period... And this is happening enough to legitimately tip the failure rate over 100%.
    I also work in open warranty case management for a major OEM here in Australia, and we have had a LOT of issues with Seagate. Before this job I worked as a builder/designer for a chain of stores, and there was a particular brand of Seagate 500gb drive that lost us a LOT of customers due to the high rate of failure. Its not an anecdote, a Google search will unveil the real data: Seriously AVOID SEAGATE PRODUCTS.
  10. HeavensCloud
    HeavensCloud Oswego, not shitty as Buffalo
    7,465
    Feb 7, 2008
    I have a Seagate 3tb in an enclosure on my desk for back-ups. Hrmm.
  11. Brian_B
    Brian_B 2[H]4U
    3,308
    Mar 23, 2012
    It'll be fine so long as you never turn it on, apparently.
  12. Trimlock
    Trimlock [H]ardForum Junkie
    15,157
    Sep 23, 2005
    Lol!
    Way back when these drives were the cheapest component in your pc I had 5 of them. The last one lasted until 6-9 months. I still have their replacements in my closest.
  13. Trimlock
    15,157
    Sep 23, 2005
    Are you referring to the clicking drives? I think mine were the 640gb variant and I had to move my pc out of my room due to that annoying (and ultimately dying) click.
  14. c3k
    c3k 2[H]4U
    2,099
    Sep 8, 2007
    LOL...The only drives that have failed me were Seagates. I stopped buying them years ago.
    Agree that class action is good in as much as it reduces Seagate profit, but it only puts that money in the lawyers' pockets. The folks who lost data are not gonna see a dime.
  15. {NG}Fidel
    {NG}Fidel [H]ardness Supreme
    6,287
    Jan 17, 2005
    My Datacenter uses a lot of Seagate drives. Not many drive deaths, we also carry WD before any one gets upset lol.
  16. staticlag
    staticlag [H]ard|Gawd
    1,675
    Mar 26, 2010
    The problem was only with 3 tb seagate. I have 20 of them, lost about 10 by the 3 year mark. Terrible drives
  17. izx
    izx Limp Gawd
    302
    Jul 30, 2007
    Hahaha, I have an NIB seagate Expansion 3TB from a couple of years ago. Was planning to shuck it now and see if it holds up to various torture tests, or maybe just get rid of it on eBay.
  18. M76
    M76 [H]ardForum Junkie
    9,455
    Jun 12, 2012
    I've seen similar failure rates among all brands, and I have lots of 3TB seagate drives, but 3TB WD Greens failed just as much.
  19. rat
    4,915
    Apr 16, 2008
    I've been seeing high failure rates with the 2TB drives, too. The infamous 7200.11 line with the botched firmware updates. Seems Seagate pretty much went steadily downhill once they bought out Maxtor. (Something a lot of us predicted on the forums.)
  20. drescherjm
    14,475
    Nov 19, 2008
    I had quite a few RMAs on 7200.11s at work however not a single one with the firmware bug. Although with the rate of failure (> 10% per year) not sure if I can call myself lucky.
  21. Spartacus
    Spartacus [H]ard|Gawd
    1,914
    Apr 29, 2005
    I have a couple of old Seagate 250GB drives that I bought in 2008 for a RAID-0 and they are still
    running strong split up into different machines now.
    Replaced them with a Seagate 512GB SSD that's been running fine for a couple of years.
    Seems to me all of the manufacturers have had some trouble with the large 1TB and up drives.
    It makes sense though since the higher data densities are more error prone. Small surface
    defects take out more data than lower density drives.
  22. GotNoRice
    GotNoRice [H]ardForum Junkie
    9,212
    Jul 11, 2001
    In all the computers that I've worked on, 9/10 of drives that have failed or are in the process of failing are Seagate drives. The other 10% are mostly WD Green drives. I'm talking about hundreds of drives. This isn't just a coincidence. I do everything I can to avoid Seagate these days yet I still have piles of dead Seagate drives on my workbench. Only saving grace is that when they fail, they usually fail "slowly" to the extent that you can usually still recover some data from the drive. Some, after a clean format, are even potentially useful as junk storage. Nothing important of course, but great for old porn.
  23. rkd29980
    rkd29980 Limp Gawd
    167
    Oct 19, 2015
    Porn isn't important?
  24. Bowman15
    Bowman15 [H]ard|Gawd
    1,237
    Apr 7, 2015
    We had a SAN that had about 32 Seagate 1TB drives that have just about all failed. Apparently they had a "bad" batch but would only replace them when they failed. Took about 3 years but they did. We've moved away from Seagate.
  25. GeneO
    GeneO Limp Gawd
    234
    Mar 1, 2012
    Their enterprise class drives seem OK. Their consumer grade drives are another story.
  26. peppergomez
    peppergomez Gawd
    713
    Sep 15, 2011
    I had 4 of the ****ers in RAID 5 and 2 of them died in such rapid succession that I lost my data. Thankfully 80% of it was backed up, but that's still a lot of lost data. I joined the lawsuit.
  27. izx
    izx Limp Gawd
    302
    Jul 30, 2007
    Their 6TB enterprise (SATA) drives are relatively cheap (for enterprise) and are working well for me so far -- not much more expensive than the HGST NAS drives and better claimed reliability with longer warranty.
  28. izx
    izx Limp Gawd
    302
    Jul 30, 2007
    My experiences with reliability on the 750GB and 1.5TB WD Greens were terrible. Never again -- rather a Seagate 5900 than a WD Green (or as deceptively rebranded recently, the "WD Blue").
  29. mwroobel
    4,942
    Jul 24, 2008
    Far be it from me to defend Seagate...... But....... The VAST majority of the 3TB drives that have been dropping like flies at Backblaze are drives that were purchased soon after the flood. They sent employees out across the country (literally) and offered cash to customers for every external drive they could get their hands on. They then ripped the drives out of the USB cases and plugged them in to SATA ports. Seagate external drives, especially the Backup and Goflex series are binned drives that were unsuitable for either the usage patterns or duty cycle with which they were utilized. The Barracuda series drives (see comparison chart here) utilized by these externals are low duty cycle specced for only 8x5 (not 24x7) and the externals were generally binned versions that were low-priced externals because they couldn't meet even the diminished specs of the regular internals (another reason they only had a 1 year warranty instead of the standard 2/3). That being said, Of the hundreds of drives I have ordered over the past year for myself and for work, NONE have been Seagates!
  30. Master_shake_
    Master_shake_ [H]ardForum Junkie
    9,384
    Apr 9, 2012
    what is the warranty in the uk on seagate drives 2 years or 1?
    also, why are the 2tb drives great compared to the 3tb?
  31. izx
    izx Limp Gawd
    302
    Jul 30, 2007
    It's the same in the US for internal desktop/external drives. You get better warranties for their Enterprise drives.
    Probably because they were, in general, more mature technology. The 4TB Seagate drives have also been decent, while the 5TBs have been flakier.
  32. AlienTech
    AlienTech Limp Gawd
    286
    Sep 30, 2004
    Seagate has gotten far tougher in warranty than before when they made average drives. The replacement drives are often sub par rejects and have a 30 or 90 day warranty. I got a drive back that developed faults in under 20 hours and it has 100 hours now as I use it only as a backup. It is also getting risky to buy drives on line as many are pulls or OEM and such and Seagate don't warrant them either. Although some people have said they got better drives as replacements, I have noticed I have always got pretty old drives back even when I sent back drives with less than 100 hours on them. I have never used a replacement as a main drive from them ever.. You can clearly see the drives have been abused for a few years and are untrustworthy. Which all shows there are a LOT of returns since drives I get form others have always been brand new and not just refurbished ones. Reformatting and clearing the smart dont fix the drive problems. It only masks out the problems the drive had experienced and they know it too which is why they have such short warranties. This is like those people who pour sand into the oil for leaky car engines to sell them so it runs fine for a few months before crashing.
  33. AlienTech
    AlienTech Limp Gawd
    286
    Sep 30, 2004
    This has to do with them using damaged platters which had water damage. The drives should have been the same as they all use the very same electronics, platters and heads.. I dont believe some of the articles where they say it was leaks and dust and stuff.. If so that would have made all their drives similar.. They made those 2 TB drives for ever and milked it as a cash cow and are still using it for all the drives upto 5TB. Yet the 4TB drives now have better reliability showing they ran out of those old damaged platters and now have no problems. Also "SOME" drives uses special software which are Limited which causes problems. You might not have noticed those problems on regular drives but the limitations cause excess wear and tear on the drives and dont work well in many situations.
    Also all of them had problems with 3TB, so I am guessing the manufacturer of the platters also damaged a lot of their inventory. As most of the components are again made by 3rd party.
  34. FLECOM
    FLECOM Modder(ator) & [H]ardest Folder Evar Staff Member
    15,589
    Jun 27, 2001
    ya we have had a pretty high failure rate of seagate 7200.11 and 7200.12 drives... but nothing beats our WD Raptor failure rate... we were RMA'ing so many Raptors to WD via Dell that WD and Dell flew down a team to find out why... they brought this fancy SATA protocol analyzer and put it between the mobo and the HD and left it running overnight... as luck would have it the next day the drive in that workstation had failed (dumb luck I guess)
    didn't hear back for about a month and then got a delivery truck 10 pallets of WD Velociraptors sent all the Raptors back and had a much easier life
  35. SomeGuy133
    SomeGuy133 2[H]4U
    3,447
    Apr 12, 2015
    wow....
  36. capt_cope
    capt_cope Gawd
    917
    Apr 12, 2009
    Seagate and maxtor drives make me cringe. I knew a company that legitimately considered a copy of important data on a single external drive a "backup". The external drive in question? A LaCie Big Disk with two 500gb drives in a striped array for 1tb total storage... Guess how that turned out?
  37. SomeGuy133
    SomeGuy133 2[H]4U
    3,447
    Apr 12, 2015
    like this :D
    [​IMG]
  38. Slava
    Slava 2[H]4U
    2,316
    Mar 20, 2002
    I use to buy Maxtors and Seagates. I believe most of them died. The last drive I remember died was Western Digital raptor 36gb. It was the only WD that actually died. I have all Western Digital drives now and Corsair SSD. Love them :)
  39. ufokillerz
    ufokillerz [H]ardness Supreme
    8,047
    Dec 17, 2000
    i think i had 8 or so of these backup plus drives that i took out from the enclosures and ran inside my synology nas, i think 5 of them failed on me. They only came with 1 year warrantys to begin with. and voided once removed from the enclosure. i have a nice stack of dead barrucudas..
