SD cards and OSX
Liver
I need to clone an SD card (Pi hole application).
How do I do that with a 2018 MBP?
Thanks.
Verge
buy adapter
copy to /
take out old card, put it new card
copy data back to new card
Archer1212
Disk utility should let you make a disk image of the card then you can just image it back on.
Otherwise, you are looking at doing a ditto command to make sure you get all the files.
