SpeedSlayer
- Mar 15, 2002
I purchased a 2gb Lexar SD card. Turns out, after buying it I learned that it doesn't work with all readers.
Are most 2gb cards like this, or did I just get the shaft??
Is there anything I can do to correct the problem
The reader I am talking about is the Toshiba SD Controller Type-A on my laptop (M205-S810, Protege Tablet PC)
Thank You
Thank You
