Scythe Kaze Master - does it control fan speed based on temps?
malicious
i must have read 5 reviews and still can't answer this question....
if it doesn't what is a good controller that does change rpm based on temps?
DedEmbryonicCe11
known12345
I have the Scythe Kaze Master and it does not control fan speed based on temps. Temp monitors are optional to put on and even if you put them on they in no way they affect fan speed. In fact I think the temp probes are relatively useless seeing as they only measure the temp of the component you put it on, IE. the heatsink, which may be ALOT cooler than the actual unit underneath the heatsink. Id rather just fire up Core Temp, or CPUID Hardware Monitor, or my BIOS software to determine the temp of the component and adjust fan speed accordingly. Though the temp probes have been useful in measuring RAM temperature.
beacon
I have this as well.
It doesn't smart regulate, just that knob.
I don't even have the LEDs/alarm running, I just use it as a straight voltage controller for my fans. Works well, but there are probably cheaper alternatives.
