YeOldeStonecat
- Jul 19, 2004
First one...
Echo off
Ifmember "terminalserverusers" goto map
:map
echo off
del t:\temp\*.*
net use /delete t:
REM Use Subst to map s to the /sun directory
subst s: c:\sun
net use t: \\%computername%\temp\%username%
md t:\temp
But I get a Windows Script Host error upon logon...
Line:2
Char:31
Error: Expected end of statement
Code:800a0401
Originally it was..,below, but I got some similar error
Echo off
If member==terminalserverusers goto map
:map
echo off
del t:\temp\*.*
net use /delete t:
subst s: c:\sun
md t:\temp
Next script giving me an error
subst t: c:\users\%username%
net use s: \\terminal\sun
But I get another windows script host error upon logon
Line:1
Char:12
Error:Expected statement
Code:800a0400
Now...both of these scripts are being pushed out via GPO from SBS03r2. The machine they are intended to run on is a new terminal server, running 2008r2. I did a GPO with loopback, user config, logon...shoved those two VBS scripts there.
I'm not a scripted, I'm a fan of old school logon bats. But I'm following the scripts that the software company gave in their Citrix/terminal server guide for installing their software on a terinal server.
Servers name is "terminal"....original huh?
Echo off
:map
echo off
del t:\temp\*.*
net use /delete t:
subst s: c:\sun
md t:\temp
Line:2
Char:31
Code:800a0401
Echo off
:map
echo off
del t:\temp\*.*
net use /delete t:
subst s: c:\sun
md t:\temp
Line:1
Char:12
Code:800a0400
