Screensaver issues
vortexware
I have been using this screensaver for years with no issues, it has an option in settings to mute the sound it makes when the screensaver is on, for some reason after couple weeks after upgrading to Win 10 the setting to mute the sound no longer saves, no matter what i do, i tested this on my work computer and boom the sound mutes so its not a compatibility issue, any idea?
KiTT Screensaver
kennyluu87
Have you tried to uninstall and reinstall? If you had it installed on a windows 7 and upgraded to windows 10. The install might not have the appropriate files/script to be compatible with windows 10.
vortexware
I tried yes, same result, i did do an upgrade but it worked just fine till like 1 week ago....
