mrjayviper
- Jul 17, 2012
I believe the issue is best explained using an example:
I ran this command (cat /etc/samba/smb.conf) on 3 servers:
1. server running FreeBSD 10.x (equivalent path as the path is different on FreeBSD)
2. server running RHEL 7 (equivalent path as the path is different on RedHat)
2. server running Ubuntu Server 16.04/17.04 (with latest patches)
My smb.conf is easily around 100 lines so I cannot view the output without using "more" command or "scrolling back".
On FreeBSD and RedHat, I can use the vertical scroll bar to easily view the complete file contents without having to use "more".
BUT on Ubuntu, using the vertical scroll bar is useless. I believe this is best explained with a pic.
As you can see, the login message somehow "covers" the beginnings of my smb.conf. I'm not sure which setting to change so I can have the same behavior like when connected to FreeBSD/RHEL7.
For reference, this is the beginning of my smb.conf
Any ideas how it can be done? Thanks a lot
