Scratch on 2007FP's anti-glare coating -- how to fix?
akwok
Hi all,
I recently bought a refurbished 2007FP off of eBay for cheap, and when it arrived there's a small 2cm scratch on the screen. On a bright white background, the scratch is multicoloured, while on black it's invisible. When I run my finger through it, I can definitely feel it. I'm assuming it's a scratch on the actual anti-glare coating.
Is there an easy way to fix this scratch? I'd rather not send it back to the seller as it'd probably cost me 25% of the monitor's value in return shipping. I've tried the vasoline and eraser methods, but they didn't work.
Thanks!
