Megalith
24-bit/48kHz
- Aug 20, 2006
Recent tests by SoundGuys confirms what most audiophiles already knew: when it comes to Bluetooth headphones, “wired is still king for quality.” The fundamental issue is that most BT codecs have “measurable quality issues,” preventing wireless headsets from sounding as good as their simpler brethren.
Every single Bluetooth codec out there exhibits a higher level of noise than wired audio, though only AAC, SBC, and LDAC 330kbps exhibit audible noise. Where wired audio can handle CD audio and 24-bit music, Bluetooth headphones simply can’t, though 24-bit is dramatic overkill anyways. If you like your music loud, Bluetooth will be noisier than wired listening, depending on how high you crank it.
