Scan the Entire Internet in an Hour or Less
Discussion in 'HardForum Tech News' started by MajorDomo, Aug 20, 2013.
  1. MajorDomo
    MajorDomo [H]ard as it Gets
    74,856
    May 9, 2000
    Now you can scan the entire Internet and see where the end really is. :D A research team at the University of Michigan have developed ZMap that can do the job quick as a wink and showed off their handiwork at the Usenix security conference on Friday.
  2. FiveFig
    FiveFig Gawd
    517
    Jun 27, 2011
    faster torrents in 3, 2, 1...
  3. Ehren8879
    Ehren8879 [H]ardness Supreme
    4,258
    Sep 24, 2004
    more ip scanning in 3...2...1
  4. Ocean
    Ocean [H]ardness Supreme
    4,924
    Oct 19, 2003
    the author wants an apple?
  5. blitzkommando
    blitzkommando Gawd
    886
    Oct 25, 2009
    I read that as "Unisex" at first.
  6. Exavior
    Exavior [H]ardForum Junkie
    9,660
    Dec 13, 2005
    Impressive, do have to wonder though how that could be used for wrong. if current scans take longer that is a good thing as it limits how fast somebody can port scan your network, also reduces the load on the network. If you suddenly can scan every device in a mater of minutes you are taking what was a few hours or days of traffic and making it now a minutes worth. So somebody could start up multiple scans and flood a network faster. Also you have now made it much easier for somebody to do a full port scan of your network in a few seconds instead of a few hours.
  7. DF-1
    DF-1 2[H]4U
    2,577
    Jun 17, 2011
    I did too.
  8. Godmachine
    Godmachine [H]ardForum Junkie
    10,472
    Apr 7, 2003
    What about entering Google into Google..
    Isn't that just as effective?
  9. Track Drew
    Track Drew Limp Gawd
    511
    Dec 6, 2007
    The software is capable of scanning one port over the entire IPv4 address space in less then an hour using a symmetrical 1 Gbps internet connection.
    If you want to scan more then one port, or have less then a 1 Gbps connection, things will obviously take longer.
  10. MRAB54
    MRAB54 Gawd
    834
    Sep 9, 2001
    So you're telling me this isn't going to work with my 4-5mbps up time warner connection? :(
  11. JimmayLong
    JimmayLong Limp Gawd
    333
    Jan 26, 2010
    it will work just a fuction of time at that point. Also assumes TimeWarner doesn't flag you..
  12. drescherjm
    drescherjm [H]ardForum Junkie
    14,526
    Nov 19, 2008
    I would hope that they would cut off your access quickly after starting such a scan.
  13. Greyryder
    Greyryder Limp Gawd
    453
    Apr 18, 2001
    Well, this should make it so much easier to get the internet on a floppy disk.
    Aaaand, I just dated myself.... :(
