sbs 2011 essentials - hardware suggestions
bmmorgan06
I am going to set up a small business server with sbs 2011 essentials. there will be about 8 workstations connected to the server. The applications are not too resource intensive. It is for a financial services firm (accounting/tax).
I need a reliable server that will last. What would you suggest for hardware? Can you load it on a desktop setup w/ an i5 sandybridge config?
What hardware would you suggest?
Yes, you can. I'm running the Standard version on a Core2Duo 2.66 with 8GB's of RAM (lower than min specs on CPU and min on RAM). It runs fine with 4 workstations - more are coming soon.
The i5 will do great for it, just make sure you have at least 8 GB of RAM. Mine ran good with 4, but had to up it to 8 for the business needs.
thanks for the advice
I will probably do a build based off of the 2500k i5 proc then.
I am thinking about this Mobo: MSI P67A-GD65 I just want something reliable! (maybe i should go intel)
I'd suggest going with ECC ram on something being put in an actual work environment.
From the looks of it, If I go with a Dell or HP server. I will be spending 2,000-2,500 for these requirements:
8GB Ram
4 hard drives w/ raid capability on board.
possible redundant PSU
SBS 2011 essent.
Does that sound right? I guess you get what you pay for...
8GB Ram
SBS 2011 essent.
might be able to build one for around that price, BUT when a drive fails or a cpu or memory psu etc etc, you have to RMA it all your self, and that can take loads of time etc etc.. with dell / hp they send the parts over night OR within 4 hours ( depending on your support / warrantee package )
Where i work up here,, when a dell server fails or has issues, the parts are sent next day air by 9am OR within 4 hours of the issue happening, ( depending on support package )
As everyone on here states, the more ram the better, sbs loves ram.
I just bought a client a T110 with Xeon 3.1, 8GB, 2x500 in raid 1 with h200 and 3 year with the sbs2011 essentials was around 1200-1300 I think.
I spec'd out a T110 II (the T110 isn't listed anymore). I spec'd it out with the above hardware & it is running 1500 without sbs. Maybe prices have jumped?
It's was a special when I selected the t110 model. Look a little more on the site maybe try selecting first server solution
you are correct. I can spec out a nice T110 II server with 8GB memory & 2 HDD for about 1100 bucks before sbs...not bad
