SB61G2V3 with VGA Silencer 9800pro?
Archonius
I am planning on buying a SB61G2V3 but it seems the AGP slot is all the way at the edge of the mobo... my AIW 9800 Pro has a rev2 Arctic silencer on it, takes up an extra pci slot space in a regular case. So in this shuttle case it would extend out of the case, correct? I would either have to run the system without a cover or do some clever modding to the side??? is this safe? :confused:
[EDIT]
sorry posted in wrong forum...
sure its safe
you can either leave the cover off
or cut a slot in the side cover, to slide it around the AC silencer
