Does anybody know what the differences are between Motorola SB5100 Hardware Versions 1 and 3?
I have a SB5100 v1 modem ... config file I'm getting from Comcast won't load ... upstream signal level does not register in the signal page ... doesn't seem to be a issue since everything works fine.
Could the config file be compatible only with a SB5100 v3 modem?
SB5100 is DOCSIS 2.0 certified.
Software Version: SB5100-2.3.0.3-SCM00-NOSH
Hardware Version: 1
MIB Version: II
GUI Version: 1.0
VxWorks Version: 5.4
2008-12-12 18:09:44 6-Notice 0x041D0318 SW Download INIT - Via Config file d11_m_sb5100_silverpboost_c01.cm
2008-12-12 18:10:25 4-Error 0x041D0570 SW upgrade Failed after download - SW File corruption
2008-12-12 18:11:20 5-Warning 0x03F000DE Map Reject - Downstream Traffic Flow Not Mapped to BPI+ SAID (EC=8)
Are there any tools available to check the configuration of my modem?
Hardware Version: 1
MIB Version: II
GUI Version: 1.0
