Silent Assasin
- Aug 1, 2004
So a litle more then a year ago, I set up my first wireless network using the WRT54G. It was still only version 1.0. I have the router set up in the basement, I tried using my laptop on the back porch, and I had a very horrible connection. I then started to look around for a different solution. This was before the high gain antanaes for the router. And then I can't remember how, but I found this firmware program called Satari. It gives you tons of more feutures then the standard firmware put out by linksys. One of which allows you to boost your siginal strenght by raising your xmit power (basicly overclocking the router).
But anyway, just recently my router has been disconnecting from my cable internet modem. And I find myself hard restetting it at least once a day in order to gain internet access. I can still access my router and ping other computers on the network, but neither wired nor wireless can access the internet until I reset the router. Does anybody have any idea what is going on? I've alread tried cloning my mac address, disenabling WEP, and several other things. Or could this just be a dreaded failure from esentially overclocking my router, but if this was true, I don't know why the wire switch would be effected......
