Sottilde said:You know, if you're going to spend that much on a video card... I would grab at least a 17in screen... one that can handle a high refresh rate. That'd be a much bigger upgrade than a new video card...
Anandtech said that this card was born from a lot of R480 dies that ATI sold to Sapphire on the cheap to clear R480 inventory as R5xx production ramps. If you are considering jumping on this, I wouldn't wait, as the supply is probably fixed and may never be replensihed.Lazy_Moron said:Well, it seems like this card might be also short lived. The X1600 also sounds really impressive, and will probably perform better than this card. Its only 50 dollars more also. Smart Shader 3 support, 12 pipes(still doesnt mean its not going to be fast, since pipes arnt the only factor these days), and higher clock speeds.
Lazy_Moron said:Woot, the prices of this card are dropping on the Egg. Once its around 200-210 and in stock im buying this card so fast.
Stereophile said:I wish it would be 200 again. It's in stock for 249.99
http://www.newegg.com/Product/Product.asp?Item=N82E16814102596
I bet the 200 dollar oem never comes back. Word gets out fast on these and newegg marks them up according to demand.
PCfetish said:isn't it still a steal at 250?
basically 850 xt pe for 250?
Lazy_Moron said:Its still a good deal. Its just it used to be $200 and then some price gouging happened before I got the chance to order one. I know if I order one know, it will go down to $200 again in the next week.
DougLite said:Your sig system? How many amps on +12 does your PSU provide, and what brand/model # is it?
u crazy.....why not juss get an x800pro instead?diablo111 said:It's out of stock...
For $200, I think I'll just pick up a 6800 nu...PCI-e, 256MB...
Jonsey said:Ah, I live for these moments:
http://www.newegg.com/Product/Product.asp?Item=N82E16814102595
That's a $200 OEM GTO2, at least when I posted.
N H O said:u crazy.....why not juss get an x800pro instead?
ND40oz said:Head over to anandtech if you need help flashing your card as well. Some guy posted an iso of bootable dos cd with both the modded bios and original and you pretty much just have to pick a number as to which flash you want to do. Very handy to have around if you ever want to go back to stock.
As for the question about unlocking the pipes and not overclocking it, it'll perform almost identically to a stock X800XL.
Leon2ky said:I'm seriously considering selling my X800XL and getting one of these. But I'm currently waiting on a answer from my mate for a 7800GTX dirt ass cheap (like $200 cheap), if he doesn't come through I may get one of these, but I'm still afraid I'll get like a shitty core that won't beable to beat my current X800XL.
