styckx
- Aug 16, 2003
saw this on tv this morning, pretty nice sounding
http://abclocal.go.com/wpvi/news/04132004_bb_sapphire.html
Originally posted by thebro
bet its cheaper then the 3m shit [43,000 a gal]
Originally posted by PaulMuaddib
EDIT
Looks like Sapphire is actually a 3m Product afterallL
The SAPPHIRE Suppression System uses 3M® NOVEC 1230 Fire
Protection Fluid
Something better than Fluorinert?
Originally posted by Syphon Filter
The 3M fluorinert pf5060 is £30 a litre, minimum purchase of 6litres, thats from a supplier i found in the UK. i dont know where you are getting 43,000 a gallon from...
Originally posted by Cardboard Hammer
...and leave it up to ABC to completely misrepresent reality. They make it seem as though Tyco had accomplished something, when all they did was show off a chemical designed by 3M for the purposes for which Tyco (among others) is using it. Also, "SAPPHIRE" is the system, not the chemical. I surprised they didn't find a way to incorporate rocket engines into this fine piece of misreporting.
well i was just saying
i saw it for $24 an ounce
Not really that big of a deal. It's intended as a Halon replacement and is volatile at room temperature / atmospheric pressure and has a boiling point of 120.6 F and freezing point of -162.4 F. It also breaks down on exposure to UV (including sun light).
Doesn't look to be of much practical use to the enthusiast, unless designing a fire suppression system for one's computer room.
