sapphire rx vega64 in a silverstone ft05 case - will it fit?
Discussion in 'AMD Flavor' started by Jedibeeftrix, May 25, 2018.
  1. Jedibeeftrix
    Jedibeeftrix [H]Lite
    100
    Dec 1, 2016
    yes, the specs reported give me 2mm of play, but in practical terms of finagling it into place, will i be able to get it in?
    or will i just end up returning it?
    no case-modding.
  2. Phelptwan
    Phelptwan [H]ardness Supreme
    6,496
    Jul 20, 2002
    Check out your cable routing first. I ended up having to do a few major changes for some silverstone cases because cables had to be route through the areas that had "room" for cards.
    But it is possible to fit big cards in silverstone cases...
