Sapphire 6950 Toxic Edition in stock @ Newegg
MendeZ
I wonder how much of an upgrade this will be over my xfx 6950 1gb... I also wish these had come in stock before BF3 beta ended. Also does anyone have any instructions on whether I need to uninstall my current amd video card drivers, as well as if sapphire has released a bios update yet? to fix the 20% issue? Also should I boot up first without switching the bios switch, or should I just boot up, install drivers, shut down, flip bios switch then check if shaders are unlocked?
samuelmorris
Well none, unless you were out of video memory - AMD aren't like nvidia where if you buy the same product with more memory it's faster. An HD6950 is an HD6950, and that's an end of it.
Rhyick
Yep, though BF3 will usually take all of the VRAM that is available to it, so you should hopefully see some improvement. I couldn't tell you for sure since the BF3 beta never ran on my system! Freaking Origin error. :rolleyes:
As for the BIOS update, there definitely is one out, as the HardOCP review of the 6950 Toxic had it with it updated. Whether or not it ships stock is another story, but then again, we'll probably be using the 6970 BIOS from the switch (providing it unlocks) anyways.
samuelmorris
You had to persevere, I had problems with Origin too, but making a new account fixed it. Not that you can play the beta any more.
MendeZ
so the 6970 bios on the 6950 doesn't have the 20% issue?
Iching
I am really considering an upgrade from Asus HD5850 (950/1200) crossfire but the gains are not that substantial. Am I missing something? I play at 2560x1600.
samuelmorris
From two HD5850s to two HD6950s it'd be about a 35-40% increase at 2560x1600, more in games that use more video memory or tesselation (increasingly common). Still not enormous though. Obviously, if you went from two 5850s to one 6950, that'd be a downgrade in most cases.
Iching
I will wait for BF3 then. it does not seem to worth it unless I can get HD6950 crossfire for $350.;)
MendeZ
has anyone in canada ordered the 6950 toxic this week? I ordered mine and it is shipping from los angeles, like what the hell, how long does that take its like 3500km jesus. I swear to god if this card is broken...
Magnite
Well your other option would have been going through canadacomputers or tiger, but they both have it ridiculously overpriced at the moment.
HeavensCloud
Oswego, not shitty as Buffalo
I think it would be Tri-fire, but I would like to see the looks of that set up.
dfedders
Its not really a 6970 bios. Its just a 6950 with the shaders unlocked. It still had the 20% issue.
I don't think they ever officially released the "fixed" bios. Its not available on their site, and their support doesn't have a clue. Its possible newer units may be fixed, but they never released the bios for download.
Spudsdude
My cards came with the updated bios (about a month ago) so I would say it's a safe bet the new ones also have it on there.
One of the first things I did is submit it to techpowerup's site (vga bios area), it still never appeared there.
Here's the bios on rapidshare, mod's if this is against the rules please remove the link.
https://rapidshare.com/files/4045339177/6950_toxic_2gb_unlocked_bios.rar
MD5 of the bios is included in the file.
The MD5 Hash is as follows
7a0a79a46b18f1cb0522142c671fda4b Cayman.bin
dfedders
Spudsdude, I still had the same throttling issue with furmark with your bios where I had to bump the power up otherwise it would throttle back.
Spudsdude
very odd that I don't have that issue with 3 of the cards using that bios. if you export the bios and then do a file compare on it, is it the same bios (i.e. did the flash actually work as expected)
Rhyick
Yeah I really hope they didnt make it so these don't unlock anymore.
Update for you: Got mine in today, put it in, saved the BIOS first (just in case), and then shut down and flipped the BIOS switch. Fortunately for me, it unlocked! Success! Now time to overclock. :D
MendeZ
Congrats, mine still has not arrived! it started off in los angeles, last thing it has said is Left via VANCOUVER, BC depot, get to toronto already! :( It said this like last thursday, I am hoping it arrives tommorow.
oh yeah, let me know what you overclock it to and what your temps are before you do thanks! also did yours come with the free dirt 3/deus ex? last question what did you use to save the bios?! sorry for the 20 questions :D
MendeZ
So I got my card today, put it in read 700 shaders, windows manually updated it and it showed 1408, so i installed ati drivers, shut it off, flipped the switch to the right side, turned it on, and still 1408 shaders. I am so sad right now. Looks like I am one of the unlucky few who got one with no 6970 bios. Can anyone tell me how to check if I need to turn the 20% powertune on and if I should even try to flash it to a 6970. How do I find out if my shaders are laser blocked?
Rattle
I got 2 of these monday, I flipped the switch right away then installed them and the drivers and 1536 no issues.
Try reinstalling the drivers if you havnt flipped the switch first. not the other way around, might make a diff...
MendeZ
which position is your bios switch on? the left or right? also how come when I put powertune to 20% its still capped at 725mhz
also how do I know which bios is the 6970 one?
when i uninstall everything its at 704 shaders on the default one until drivers get installed.
Okay scratch that, everytime I uninstall drivers and flip the switch, even after windows does its random install of the card, it still shows 704 shaders in gpu-z until I install amd drivers.
Bladestorm
I'm expecting two of these cards on Monday that I bought of off Newegg, and now Amazon is selling the HIS 6970 for $224! It's a price mistake I'm sure, but not enough of one that they still might honor it. Do I refuse delivery of the 6950's on Monday, and put in an order on Amazon right now? I'm in a bit of a conundrum. It would save me $140, and I'd get guaranteed 6970's. Beyond the cost savings, I'm worried the Toxic 6950's wont unlock. :(
Rhyick
Yes it came with Dirt 3. No Deus Ex. I used Trixx to save the bios. I haven't OC'ed it yet (haven't had the need to), but I will over the weekend and let you know the results. :)
Spudsdude
since it's an out of stock item with a wrong price, odd's of getting it are very slim, if it was in stock they would honor the price (if it's not too far outside the normal price error range), it could also be the wrong part number and description
in the end it's up to you
MendeZ
I have come to the conclusion mine will not unlock :( I tried using winflash, rbe, nada, i tried overwriting the 6970 bios I downloaded with the 6950 bios which is suppose to be 6970 bios, still won't work I get unable to write image or w.e even using command prompt it would not work with different bios, this blows but what can I do... I seem to somehow have resolved the powertune issue with all this tinkering. I don't even have it set to 20% yet gpu-z is showing it running at 880hz/1300 without dropping while metro 2033 is on, so this means I dont need to set powertune to 20% right? are there any other methods I could try or to verify for sure the shaders are laser blocked? I also tried uninstalling the drivers completely and then flipping the switch still shows 704 shaders and then 1408
Lord_Exodia
Wait, were you actually able to flash a bios to the card and are you sure your trying to overwrite the correct bios? Too many people keep confusing the switch position on this card.
Spudsdude
Which version of winflash did you use and what error did it return?
Which position was the switch in when you tried to flash?
MendeZ
No I do not think I was able to flash the card, and the switch was in position 1 I believe, the switch was on the side closer to the fan on the card. Yes I do think I was trying to overwrite the correct bios :/
Lord_Exodia
For shits and giggles flip the switch to the left (away from the fan and check using gpu-z and see how many shaders it says. Also try flashng over that bios. IF it is the fail safe it wont let you flash over it. Perhaps the writable bios is actually to the left side and the opposite of a reference design card like the ones I have?
MendeZ
I'm pretty sure I tried both sides of the switch, neither worked :(
Lord_Exodia
The system has to be off, then flip the switch and let it boot up. If you flip the switch while in windows it's too late the other bios was loaded already, at that point flipping the switch does nothing unless you plan to flash it to overwrite the secondary bios. Have you tried shutting down and flipping the switch?
MendeZ
Yes I have multiple times, completely powering it off, still nothing.
I am kinda confused as to how I fixed the powertune problem, I must have done something for it to work properly at not be capped at 725mhz without 20%
MendeZ
hm quick question, could mine perhaps not have unlocked because I put it in, and installed the drivers and then preceded to flip the switch, thus making it so that the card was stuck on 1408 shaders? perhaps removing it from the pci express slot or putting it in the other one will make it work?
emyrl
Your might just have been unlucky with the card. I unlocked mine after installing drivers and then flipping the switch. My room mate on the other was unlucky and his didn't unlock either.
MendeZ
well this kinda sucks.. should I rma it or is there not much of a difference between the 6970 and 6950? how do i check if it cant be unlocked for sure
