SanDisk Cruzer U3 how do I format to get rid of U3?
Discussion in 'General Software' started by Hofy, Jan 4, 2007.
  1. Hofy
    Hofy 2[H]4U
    2,471
    Jun 3, 2004
    I just picked up a SanDisk Cruzer 1GB flash drive at Staples for $20. I get home and connect it to my PC and this annoying U3 crap keeps coming up. I want to get rid of it and just use it as a regular flash drive.
    I have deleted the files and formated the flash drive. The very next time I connect it that U3 crap keeps coming back and all the files are back too. WTF??!!
  2. filthysanchez
    filthysanchez 2[H]4U
    2,669
    Jul 19, 2006
    i had to get on a mac to delete it.
    you could probably do it through ubuntu.
  3. Hofy
    Hofy 2[H]4U
    2,471
    Jun 3, 2004
    Starting up Tux right now. Will let you know if it worked. Thanks.
  4. shadowwyvern
    shadowwyvern Gawd
    604
    Sep 22, 2005
    Google showed me this I do not own one of these drives personally, and actually never will if I can help it, so I do not know if this actually works. My friend had a drive with U3 on it, but crashed it and that removed it, but this sounds a little more reliable :). I lol'd at the site's attempt to persuade you not to remove it
  5. Langford
    Langford [H]ard|Gawd
    1,339
    Apr 5, 2006
    I have removed that junk from many drives. shadowwyvern's link is the right solution.
  6. Hofy
    Hofy 2[H]4U
    2,471
    Jun 3, 2004
    Thanks, that did the trick. I was just searching wrong, again.
  7. MonsterSound
    MonsterSound n00b
    12
    Jun 13, 2006
    Thanks for the link. It worked fine. My DVD player's usb wouldn't recognize the flash drive with U3, but it's alright noooww.
  8. [LYL]Homer
    [LYL]Homer [H]ardness Supreme
    4,213
    Jun 7, 2004
    Nice, just did this with my Sandisk.
  9. PaHick
    PaHick Gawd
    785
    Jul 2, 2005
    Someone buy this man a beer. THANK YOU!
  10. ilkhan
    ilkhan No Title for You!
    13,305
    Sep 23, 2002
    um, if its a sandisk it has the uninstall utility installed as part of the suite. utilities -> remove as I recall.
  11. DeaconFrost
    DeaconFrost [H]ardForum Junkie
    11,065
    Sep 6, 2007
    The uninstall utility on Sandisk's site is the way to go...in the future. As for portable suites, use PortableApps.com instead. It works much better, and allows more freedom and customization.
