D
Deleted member 245375
Guest
Ok, so not in those particular words but, honestly I don't think it necessarily WAS the battery but instead the fact that they designed the battery space to such tight tolerances and then chose a form factor for the battery which really didn't give them any wiggle room at all. Since Li-Ion and even Li-Po batteries do tend to expand slightly when they're warm (under use or charging) they require some wiggle room, even if it's on the order of like a half millimeter on each side or something close to that, to allow for the expansion due to temps. Of course, Samsung will flat out place the blame on the batteries almost exclusively and it's not exactly correct considering the situation and the mounting aspects.
Anyway, this is the short video they just put out with their explanation which was already diagnosed way back in early September by one of the tech websites that even had X-rays done of the original batteries and then the second batch too which clearly showed the plates were bending and making contact because of how tightly packed they were in that little compartment area the Note7 has:
They also had the live stream of the event disclosing their results which can be seen here (recorded of course) - skip to 29 minutes 13 seconds to catch the very beginning and bypass almost the half hour of nothing at all:
Still seems like a shame considering that now the cause and effect is known (and has been for some time) and all those Note7 devices will just get up and destroyed. I'd say refit them with proper (and smaller) batteries which fit well and have plenty of wiggle room then re-sell them or return them to the original owners that sent them in but that's just me.
Talk about a complete waste of technology, good lord. I never owned one but at this point considering all the restrictions placed on the Note7 and the fact that sooner or later some update will sneak through and cripple it is just sad to me overall.
"The Note7 is dead... long live the Note7..."
