Samsung UN40KU6300 40-Inch 4K
baii
My only gripe is that the tv stand tilts backward... For some unknown reason, more glare, odd ergonomics.
Savoy
MIne is perfectly straight. As in no lean backward or foward. Maybe you didn't install the stand correctly?
silent-circuit
Anyone else having issues with the display not remembering picture settings? Like backlight level, color temp, etc?
cybereality
This is something that has bothered me since I got this TV and I finally figured it out. I was having trouble with Game Mode being disabled. Sometimes it would be auto-selected, but some of the time it would turn off and be grayed out. The colors on Game Mode are much better for me (even though it's supposed to be lesser quality) so this was annoying.
However, I finally figured it out (and it's silly). If the input label is "PC" then Game Mode is disabled. Simply renaming the "PC" label to something else (like "4K") brings Game Mode back as an option. So much better now.
DooLocsta
I read the same thing in the 6290 thread as well.
andy4theherd
if any of you are in to emulators... Zelda BotW running at 4k using CEMU looks FANTASTIC on this TV! with minimal "tweaking" i'm getting solid 30fps at 4k on an i5 4670k OC'd to 4ghz, 16gb ram, and a 980Ti (the gpu makes little difference as long as it is Nvidia). if you have the CPU headroom you can even run the game at 8k resolution and then downscale it to 4k to look even better. i'm not advocating piracy. buy the game and you are legally allowed a backup copy. use of emulators has been ruled legal in the US.
MaZa
Its fully playable already? If it is then I finally have a good excuse to get rid of my Wii U console for good. BotW is the only reason why I still have WiiU around and play it from time to time, otherwise it is just gathering dust.
andy4theherd
there are still a few hiccups and random crashes here and there but easily playable. i played 2.5 hours last night and the only issue i had was the stasis trial was running at 60fps instead of 30 so everything was going crazy fast. saved the game and put a 30fps cap on it using Rivatuner and went right back without issue. i imagine the CEMU emulator experience will completely surpass the Wii U and Switch experience within 2 months. the only downside now is the amount of time it takes to get everything setup and running on CEMU vs just turning on your console to play.
here is a good 4k video showing it off
MaZa
Hot damn the game looks pretty in 4K! Even though the game has some textures that are quite subpar the stylized graphics scale up really well in general. I look forward to the day it plays Zelda without kinks.
linuxdude9
Just picked up one of 55" 6290's at Walmart for $398. Hope the panel is not too different from the one in my 43".
andy4theherd
the emulator is about 80% CPU dependent so the GPU is sitting there with little to do. most people see a difference (if any) of 1 or 2 fps loss in going from the game's native 720p to 4k. Nintendo has become a master of using distinct art style in textures to hide the lack of power their systems generally have. that's why it still looks fantastic blown up to 4k.
if you or anybody else here is interested, the CEMU reddit page has all the info you need.
https://www.reddit.com/r/cemu/
Reactions: MaZa
Loftus
This is getting pretty frustrating. I set my backlight to a number. Then, over a few seconds, and without the setting number changing, the display physically "drifts" to a less-bright state. Any thoughts? I have "dynamic" settings off.
Ocellaris
The TV will dim in some dark scenes, on previous TVs you could disable this by adjusting the brightness over a certain level and then lowering the color values.
silent-circuit
You probably haven't turned off all the "eco mode" shit.
g1xx3r
So, I snagged the 40in on Ebay a few days ago for $300 while earning $30 ebay bucks so not a bad deal. Delivered today and set up with my new Aorus 1080ti NE. Didnt read through the ibire thread but so far so good. Updated the fw, got W10 to be viewable(scaling) and did some light gaming. What are the main setting I nedd to really make it shine more that it already is. I sit 4-5 feet away from my wall mounted monitor. Mostly gaming and web browsing. Coming from a 6 year old 1080p monitor, I can say it was definitely worth the money. TIA.
euskalzabe
Mainly:
1) Switch the source name to PC so you disable all processing and get a clean signal.
2) Turn UHD color on the source you have your PC connected. This will enable 4K resolution at 4:4:4 color.
That's all most people need/want. Anything else is subjective preference.
cybereality
Rename the input from "PC" to anything else, for example "4K". This will unlock Game Mode, which has slightly less lag but seemingly much better picture quality for me. If you want to use HDR or 4:4:4 color, use only HDMI 1 and enable UHD Color in the TV settings.
g1xx3r
Mainly:
Much appreciated guys. Im after the best picture quality while gaming. Ill start with these, thanks.
andy4theherd
make sure you go into the tv settings and turn off all "eco" and "power saving" features. also make sure you don't have "adaptive brightness" turned on in the Windows power settings.
Loftus
This did not unlock anything different for me than what was available when it was just "PC" from out of the box. What am I missing?
cybereality
Have you enabled Game Mode (or was it already on)? There are some cases where it will appear automatically.
Loftus
The only Special Viewing Mode that's available is "Sports Mode".
"Game Mode" and "HDR+ Mode" are greyed out and not selectable.
g1xx3r
Ive read that "Game Mode" reduces picture quality a little..T or F.. I havent enabled it yet.
My info shows as follows..
PC HDMI 1/DVI UHD 3840x2160 /60p HDMI UHD Color
Am I set up correctly??
Also, is there a popup that shows when HDR is active?? On Netflix through the TV app, HDR movies show available, look good but there is no popup like my LG OLED has.
silent-circuit
Not sure about the built in Netflix app, but when I'm using it hooked up to my PC and play Mass Effect Andromeda or a HDR video on YouTube it pops up "A HDR Video is playing" in the top left corner.
g1xx3r
Hmm.. Just tried it and no popup. Went to the settings and it says HDR not available.. Im obviously missing something.
euskalzabe
I don´t think you are. You're using a 980Ti. I'm going from memory here, but I don't think Maxwell supports HDMI 2, does it? If so, no HDR for you, bud... As far as I can remember (again, saying this from memory without checking) it's only the RX 400 series and the Pascal GPUs that support HDMI2 and thus HDR signal.
UPDATE: Nevermind, it does support HDMI2.
Lateralus
More [H]uman than Human
I don´t think you are. You´re using a 980Ti. I'm going from memory here, but I don't think the Maxwell supports HDMI 2, does it? If so, no HDR for you, bud... As far as I can remember (again, saying this from memory without checking) it's only the RX 400 series and the Pascal GPUs that support HDMI2 and thus HDR signal.
As far as I remember, all of the nVidia 9xx series cards (in addition to the Titans of that era and anything newer) have HDMI 2.0 outputs. Both my GTX 980s and my 980 Ti did, and I know the 970 and 960 did as well.
g1xx3r
Nope, just installed a shiny new Gigabyte Aorus 1080Ti. Just havent updated my sig yet..:)
