kraken0698
- Jan 16, 2003
first, what in the heck are you playing that you can't get acceptable fps from a 1080?
from someone that has been gaming non-stop on this screen and a single OC'd 980Ti... turn AA off...... that will give you 10-15 fps in just about every game. the pixel density on a 4k 40" screen is so much that AA isn't even needed in most games. next step if that doesn't net you the avg fps you want, turn shadows down a notch. that is the next big fps killer in most modern games.
turning a couple settings down and maintaining 4k resolution will still look 100x better than keeping those settings maxed and playing at 1080p...
Playing WatchDogs 2 or BF1 gives me noticeably lower frame rates at 4K resolution. Sure, I could turn down the settings and maybe make a game playable but why not keep all of the settings turned on and just lower the resolution a notch? I find that 2560x1440 looks quite good. Like I said, the TV will do 60Hz at 2560x1440 while in PC or HDMI1 mode but when I switch to Game Console mode, it automatically drops the refresh to 30Hz.
Is there another way to enable Game Mode than switching the input to Game Console?
