SaladDressing
- Feb 21, 2011
Any new professional reviews on these Samsung PLS monitors?
So I was finally able to set up my 24" Samsung A850 this morning. I didn't have too much time to sit with it as I had to run into work. I hooked it up to my displayport on my Dell XPS 15 L502X and used it for a few minutes on default settings out of the box.
Here are some brief notes:
PROS
- Beautiful crisp clear picture! Colors look excellent and whites are very bright out of the box.
- Excellent viewing angles. This is my 1st IPS, and I love the fact I don't have to look at this monitor dead on to get the best picture.
- No Dead Pixels
- AG Coating is minimal as there is no screen door effect on white/light colors.
- USB 3.0 Hub. Perfect for my new 3.0 Portable Hard Drive and other USB accessories.
- Atheistically, this is a simple, professional, yet elegant looking monitor. MUCH thinner than my old Samsung and the materials are much nicer. Brushed Aluminum / metal surface all over.
- Monitor has many adjustments, and actually can be set very high (for pivot feature), however its great for my setup sitting behind and above my laptop.
CONS
- The bleeding / non even back-light seems to be apparent when I completely darkened my room and just had the screen turned to black. Right side was ok, seemed more apparent on left side top & bottom (see pic)
All that said, I really love this monitor and plan on keeping it. Mind you I'm not a heavy photo editor nor will I watch movies or TV on this monitor so my monitor will almost never be fully black.
Its main purpose is for work space, surfing, office work, some basic multimedia, etc. I just wanted an IPS display and this seems to fit the bill with all the features. Samsung has never disappointed me, and this monitor doesn't disappoint thus far... although I do plan to spend more time with it and try to find some optimal settings from other users.
I am interested to know if it's worth buying one from Provantage to see if I get a better monitor. Id hate to go through the hassle as I don't think this even bothers me as I mentioned above.... but if it's considered a defect, I don't mind trying my luck with another one. Here is the pic of the back light bleeding (from a cell phone):
Does anyone know if this monitor is true 8bit?
Since this monitor does 16.7mil colors does that mean its true 8bit, was reading around and 6bit + FRC can't do 16.7 but around 16.2 or something. I looked at grey scale images and it doesn't show any noticeable banding which dithering would show.
The one I have is from provantage and its the same as yours. No dead pixels. I do like the viewing angles on this screen. Image doesn't change when you shift a little to the left/right or up/down unless you move a lot.
Really? xbitlabs.com said it was just plastic that looks like metal, if I remember correctly.Brushed Aluminum / metal surface all over.
Can people use the proper model number please, it makes things less confusing.
24 inch = S24A850
27 inch = S27A850
S27A850 is true 8-bit, S24A850 is 6-bit plus FRC. A good FRC implementation can simulate 16.7 million colors and doesn't result in dithering.
Try reading the review which is linked to in the first page or some posts from the last few pages![]()
Both the 24" and 27" versions are 6-bit + FRC
Those were based on ES mate.... final refined, post-production models will obviously yield better results.
the backlight bleeding looks a LOT WORSE IN PICTURES than it does in real life. Not sure why or how, but I can honestly say that's been my experience.
The people complaining about it affecting normal use are either:
1. OCD
2. Perfectionists
3. Exaggerating
When will the S24A850 be available? Where are you guys getting yours??
is MVA better than IPS for games (response time, ghosting, input lag)??
and colour reproduction?
Is the 650D an MVA or a PVA of some kind? Samsung's website doesn't seem to specify.
the oleds right now aren't really betterAny panel you pick is a compromise....outside of OLED's that cost 8+ grand.
There is no free lunch - the angles of PVA/MVA are not as good - and the response time especially of the PVA is much much much slower.
That depends on the image being displayed. If it's a bright image, then you're right that IPS might have a bit better viewing angles. But if it's a dark image, then the IPS glow will make the viewing angles extremely poor on an IPS panel - in fact so poor that the IPS glow is visible even when watching straight on from normal distances (approximately 2 feet). Very annoying!
MVA Left, IPS Right:
http://product.pcpop.com/000282172/Picture/003861411.html
But yes if you look at a pitch black screen with no content MVA would be slightly better, but I usually have images/games/movies/applications on my screens.
Quite extreme angles, but I agree the color shift is clearly visible there. However check out this review of the Samsung F2380 MVA monitor (scroll down to the "Viewing Angles" subsection):
http://www.tftcentral.co.uk/reviews/samsung_f2380.htm
The color shift is still visible, but it's not that obvious at all.
Google powerstrip it will let you add custom resolutions to your monitor here is a good guide Link . 1280x1440 doesn't seem to be perfect as it is a bit blurry and the divider in the middle has a few pixels between the split. I also added 1920x1440 for a perfect 4:3 resolution for some older games... for some reason it was picking up 1856x1392 as my max 4:3 resolution...Has anyone been able to figure out how to change the PBP resolution of desktops to the recommended 1280x1440?
I don't have that option, yet the manual says that is the recommended PBP resolution.
Regarding the response times, they are better on MVA than on PVA (although still not as good as IPS or TN). For example the G2G response time for the S24A650D is specified at 8 ms.
Not an expert or anything - but I been reading Xbit labs for a while. And the problem with the PVA/MVA panels is that for some transistions (other then gray to gray) the speed is REALLY slow. So this will lead to visibile ghosting because the monitor will refresh before the pixel can change.
What's worse is that there tends to be response time compensation artifacts - because to get even that 8ms G2G compensation is not 'natural'.. This tends to introduce input lag as well..
There is a reason that IPS won out - its the better technology for most people..
